LAUNCHXL-CC26X2R1: What's the proper way of sending periodic advertising packets in BTool?
Part Number: LAUNCHXL-CC26X2R1
I'm using simplelink_cc13x2_26x2_sdk_5_20_00_52.A.
I'm trying to make my TI Launchpad send periodic advertising packets using BTool.
This is how I start:
1.) I'm sending a HCIExt_ResetSystemCmd command.
2.) I'm initializing my TI Launchpad as a Peripheral using GAP_DeviceInit.
3.) I'm calling a GAPAdv_create command with propConnectable = DisablepropScannable = Disable and propLegacy = Disable, in order for GAPAdv_SetPeriodicAdvEnable not to fail when calling it.
4.) I'm sending GAPAdv_SetPeriodicAdvParams with the default options provided by BTool, then GAPAdv_setPeriodicAdvData with PayloadLength = 4 and, finally, GAPAdv_SetPeriodicAdvEnable.
Everything seems to work fine, and every response I receive in the log is SUCCESS. The problem is, when trying to scan for the device with my phone (using nRF Connect), I can't find my Launchpad.
What I managed to do was also send the GAPAdv_enable command after all the 4 steps mentioned above. This allowed the Launchpad to be discovered by my phone, as seen in the picture below. Still, I can only see the periodic advertising interval, only after I expand the properties of the device. The "main" advertising interval is 104 ms, while I only wanted periodic advertising data to be sent (the 7.5 ms below).
I've also provided a log with the commands I sent, in order to achieve the result above (the 4 steps + GAPAdv_enable).
[1] : <Tx> - 01:53:57.231
-Type           : 0x01 (Command)
-OpCode         : 0xFC1D (HCIExt_ResetSystemCmd)
-Data Length    : 0x01 (1) byte(s)
 Type           : 0x00 (0) (Chip Reset)
Dump(Tx):
0000:01 1D FC 01 00                                  .....
[2] : <Rx> - 01:53:57.262
-Type           : 0x04 (Event)
-EventCode      : 0x00FF (HCI_LE_ExtEvent)
-Data Length    : 0x05 (5) bytes(s)
 Event          : 0x041D (1053) (HCIExt_ResetSystemCmdDone)
 Status         : 0x00 (0) (SUCCESS)
 CmdOpCode      : 0xFC1D (HCIExt_ResetSystemCmd)
Dump(Rx):
0000:04 FF 05 1D 04 00 1D FC                         ........
[3] : <Tx> - 01:54:04.051
-OpCode         : 0xFE00 (GAP_DeviceInit)
-Data Length    : 0x08 (8) byte(s)
 ProfileRole    : 0x04 (4) (
                  Peripheral)
 AddrMode       : 0x00 (0) (ADDRMODE_PUBLIC)
 RandomAddr     : 00:00:00:00:00:00
Dump(Tx):
0000:01 00 FE 08 04 00 00 00 00 00 00 00             ............
[4] : <Rx> - 01:54:04.073
-Data Length    : 0x06 (6) bytes(s)
 Event          : 0x067F (1663) (GAP_HCI_ExtentionCommandStatus)
 DataLength     : 0x00 (0)
Dump(Rx):
0000:04 FF 06 7F 06 00 00 FE 00                      .........
[5] : <Rx> - 01:54:04.089
-Data Length    : 0x2C (44) bytes(s)
 Event          : 0x0600 (1536) (GAP_DeviceInitDone)
 DevAddr        : F8:8A:5E:2D:8C:BB
 DataPktLen     : 0x00FF (255)
 NumDataPkts    : 0x05 (5)
 IRK            : 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
 CSRK           : DD:A8:4B:67:91:B2:52:68:5C:D9:70:CE:7C:12:F2:0C
Dump(Rx):
0000:04 FF 2C 00 06 00 BB 8C 2D 5E 8A F8 FF 00 05 00 ..,.....-^......
0010:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 DD ................
0020:A8 4B 67 91 B2 52 68 5C D9 70 CE 7C 12 F2 0C    .Kg..Rh\.p.|...
[6] : <Tx> - 01:54:16.422
-OpCode         : 0xFE3E (GapAdv_create)
-Data Length    : 0x15 (21) byte(s)
 Properties     : 0x0000 (0) (
                  AdvEventProps Bit Mask Is Not Set)
 IntervalMin    : 0x0000A0 (160)
 IntervalMax    : 0x0000A0 (160)
 PrimaryChMap   : 0x07 (7) (
                  GAP_ADV_CHAN_37
                  GAP_ADV_CHAN_38
                  GAP_ADV_CHAN_39)
 PeerAddrType   : 0x00 (0) (PEER_ADDRTYPE_PUBLIC_OR_PUBLIC_ID)
 PeerAddress    : 00:00:00:00:00:00
 FilterPolicy   : 0x00 (0) (
                  AdvFilterPolicy Bit Mask Is Not Set)
 TxPower        : 0x7F (127)
 PrimaryPHY     : 0x01 (1) (GAP_ADV_PRIM_PHY_1_MBPS)
 SecondaryPHY   : 0x01 (1) (GAP_ADV_SEC_PHY_1_MBPS)
 SID            : 0x00 (0)
Dump(Tx):
0000:01 3E FE 15 00 00 A0 00 00 A0 00 00 07 00 00 00 .>..............
0010:00 00 00 00 00 7F 01 01 00                      .........
[7] : <Rx> - 01:54:16.468
-Data Length    : 0x07 (7) bytes(s)
 DataLength     : 0x01 (1)
 Handle         : 0x00 (0)
Dump(Rx):
0000:04 FF 07 7F 06 00 3E FE 01 00                   ......>...
[8] : <Tx> - 01:54:24.918
-OpCode         : 0xFE14 (GapAdv_SetPeriodicAdvParams)
-Data Length    : 0x07 (7) byte(s)
 Handle         : 0x00 (0)
 Interval Min   : 0x0006 (6)
 Interval Max   : 0x0006 (6)
Dump(Tx):
0000:01 14 FE 07 00 06 00 06 00 00 00                ...........
[9] : <Rx> - 01:54:24.956
Dump(Rx):
0000:04 FF 06 7F 06 00 14 FE 00                      .........
[10] : <Rx> - 01:54:24.971
-Data Length    : 0x03 (3) bytes(s)
 Event          : 0x0619 (1561) (GAPAdv_SetPeriodicAdvParams)
Dump(Rx):
0000:04 FF 03 19 06 00                               ......
[11] : <Tx> - 01:54:28.680
-OpCode         : 0xFE15 (GapAdv_setPeriodicAdvData)
 Handle         : 0x00 (0)
 Operation      : 0x03 (3) (Complete_Data)
 PayloadLength  : 0x04 (4)
 Data           : 00:11:22:33
Dump(Tx):
0000:01 15 FE 07 00 03 04 00 11 22 33                ........."3
[12] : <Rx> - 01:54:28.695
Dump(Rx):
0000:04 FF 06 7F 06 00 15 FE 00                      .........
[13] : <Rx> - 01:54:28.711
 Event          : 0x061A (1562) (GAPAdv_SetPeriodicAdvData)
Dump(Rx):
0000:04 FF 03 1A 06 00                               ......
[14] : <Tx> - 01:54:32.172
-OpCode         : 0xFE16 (GapAdv_SetPeriodicAdvEnable)
-Data Length    : 0x02 (2) byte(s)
 Enable         : 0x01 (1)
 Handle         : 0x00 (0)
Dump(Tx):
0000:01 16 FE 02 01 00                               ......
[15] : <Rx> - 01:54:32.195
Dump(Rx):
0000:04 FF 06 7F 06 00 16 FE 00                      .........
[16] : <Rx> - 01:54:32.210
 Event          : 0x061B (1563) (GAPAdv_SetPeriodicAdvEnable)
Dump(Rx):
0000:04 FF 03 1B 06 00                               ......
[17] : <Tx> - 01:54:36.303
-OpCode         : 0xFE3F (GapAdv_enable)
-Data Length    : 0x04 (4) byte(s)
 Handle         : 0x00 (0)
 EnableOptions  : 0x00 (0) (GAP_ADV_ENABLE_OPTIONS_USE_MAX)
 DurationMaxEvnt: 0x0000 (0)
Dump(Tx):
0000:01 3F FE 04 00 00 00 00                         .?......
[18] : <Rx> - 01:54:36.335
Dump(Rx):
0000:04 FF 06 7F 06 00 3F FE 00                      ......?..
My question is: Why do I also need to send GAPAdv_enable, in order for my device to be identifiable from the mobile phone? Did I, maybe, do something wrong while trying to activate periodic advertising or is my workflow (from the log) the correct one?
Another question would be, where can I see the advertising packets sent? I'm talking about the data (00:11:22:33) set using the GAPAdv_setPeriodicAdvData command.
    Thank you for all the details you have provided. They are very helpful in understanding what is going on. To confirm, the device has been flashed with host_test, correct? I would recommend referencing the Periodic Advertising section of the User's Guide. It provides specific instructions with regards to how Periodic Advertisements should be configured.
    Jan
  • Hello and thank you for the reply.
    I've followed the steps from the link provided by you and, in bTool, I've sent the following commands in order:
    GapAdv_create -> GapAdv_LoadData -> GapAdv_setEventMask -> GapAdv_enable -> GapAdv_SetPeriodicAdvParams -> GapAdv_SetPeriodicAdvData (and modified the payloadLength to 4 for the default data of 00:11:22:33) -> GapAdv_SetPeriodicAdvEnable
    The problem is, I wasn't able to see my device through the app. In the link provided by you, the second command that needs to be sent is GapAdv_loadByHandle, and not GapAdv_LoadData, but bTool doesn't seem to actually provide that command, and that's why I used the latter.
    By not calling that command at all, and directly moving to the third command (GapAdv_setEventMask) after GapAdv_create, I was able to see the Launchpad in my software.
    However, I've also tried to use BluePixel's BLE Scanner app, in order to check if some data was actually sent by my Launchpad, and, I cannot actually see anything being sent. The sent data should have been 00:11:22:33, the default data provided by bTool when calling the GapAdv_SetPeriodicAdvData command.
    I've also included several screenshots, and my bTool workflow log (the one that worked, without the LoadData command).
    Hope these help, somehow.
    [1] : <Tx> - 11:06:45.044
    Dump(Tx):
    [2] : <Rx> - 11:06:45.065
    Dump(Rx):
    [3] : <Tx> - 11:06:51.335
                      Peripheral)
    Dump(Tx):
    [4] : <Rx> - 11:06:51.363
    Dump(Rx):
    [5] : <Rx> - 11:06:51.378
    Dump(Rx):
    [6] : <Tx> - 11:07:02.170
                      GAP_ADV_CHAN_37
                      GAP_ADV_CHAN_38
                      GAP_ADV_CHAN_39)
     SID            : 0x01 (1)
    Dump(Tx):
    0010:00 00 00 00 00 7F 01 01 01                      .........
    [7] : <Rx> - 11:07:02.209
     Handle         : 0x00 (0)
    Dump(Rx):
    [8] : <Tx> - 11:07:13.846
    -Type           : 0x09 (ExtCommand)
    -OpCode         : 0xFE45 (GapAdv_setEventMask)
    -Data Length    : 0x0300 (768) byte(s)
     Handle         : 0x00 (0)
     EventMask      : 0x0092 (146) (
                      GAP_EVT_ADV_SET_TERMINATED
                      GAP_EVT_ADV_START_AFTER_ENABLE
                      GAP_EVT_ADV_END_AFTER_DISABLE)
    Dump(Tx):
    0000:09 45 FE 03 00 00 92 00                         .E......
    [9] : <Rx> - 11:07:13.879
    Dump(Rx):
    0000:04 FF 06 7F 06 00 45 FE 00                      ......E..
    [10] : <Tx> - 11:07:18.680
     Handle         : 0x00 (0)
    Dump(Tx):
    [11] : <Rx> - 11:07:18.708
    Dump(Rx):
    [12] : <Rx> - 11:07:18.724
    -Data Length    : 0x09 (9) bytes(s)
     Event          : 0x0613 (1555) (GAP_AdvertiserScannerEvent)
     EventId        : 0x00000001 (1) (
                      GAP_EVT_ADV_START_AFTER_ENABLE)
     AdvHandle      : 0x00 (0)
    Dump(Rx):
    0000:04 FF 09 13 06 00 01 00 00 00 00 00             ............
    [13] : <Tx> - 11:07:34.872
     Handle         : 0x00 (0)
     Interval Min   : 0x00A0 (160)
     Interval Max   : 0x00A0 (160)
     Properties     : 0x0040 (64)
    Dump(Tx):
    0000:01 14 FE 07 00 A0 00 A0 00 40 00                .........@.
    [14] : <Rx> - 11:07:34.890
    Dump(Rx):
    [15] : <Rx> - 11:07:34.906
    Dump(Rx):
    [16] : <Tx> - 11:09:03.886
     Handle         : 0x00 (0)
     Data           : 00:11:22:33
    Dump(Tx):
    [17] : <Rx> - 11:09:03.912
    Dump(Rx):
    [18] : <Rx> - 11:09:03.939
    Dump(Rx):
    [19] : <Tx> - 11:09:26.366
     Enable         : 0x01 (1)
     Handle         : 0x00 (0)
    Dump(Tx):
    [20] : <Rx> - 11:09:26.409
    Dump(Rx):
    [21] : <Rx> - 11:09:26.431
    Dump(Rx):
    Do you have access to a BLE sniffer? If so, could you take a OTA capture of the BLE traffic when you send the specified host_test commands? This will help us verify if the advertisements are being sent out along with the data being sent within.
    Jan
    used Ellisys's Bluetooth Analyzer with one of their sniffers. This is the result:
    As I saw in a video of someone who also tried doing Extended Advertising, the Flags (from the "Extended Header" section, 3rd picture) should have also contained "Adv Data" (having the following three: "AdvDataInfo | SyncInfo | AdvData". Unfortunately, mine doesn't have this flag, meaning that I also don't have any Adv Data section with the info about the payload sent.
    I can't see the payload being sent anywhere else (I sent 00:11:22:33, together with the payloadLength=4 from bTool).
    Where can I specify "Adv Data" flag should also be used?
    Thank you.
    Got it. Thank you for taking a sniffer log. These are very helpful in allowing us to see what is going on. Did you add the USE_PERIODIC_ADV predefine symbol to the host_test project?
    Jan
  • Hello.
    We do use that predefine.
    The periodic advertising functions also return SUCCESS.
    Thank you
    Looking through your sniifer log, it does seem like the periodic advertising is working based on the Periodic Advertising section of the User's Guide. We are seeing the ADV_EXT_IND and the AUX_ADV_IND packets we expect to see in this case. Could you attach the sniffer log file to a reply in this thread so I can look over it as well? Could you try running the GapAdv_SetPeriodicAdvData commnand before calling the GapAdv_enable to see if this allows the advertising data to be seen?
    Jan
    I've attached two log files which I got from BTool.
    I've used two TI Launchpads - the first one plays the Peripheral role and does Periodic Advertising with a 3-byte data (see LogFromPeripheral.txt), while the second one plays the Central role and scans for all devices (output in LogFromCentral.txt).
    F8:8A:5E:2D:8C:BB is the Peripheral's address and, as you can see in the second file, the device is found when running GAPScan_Enable. The problem is, he data sections are empty (length = 0 and no data shown).
    [1] : <Tx> - 03:45:59.176
    -OpCode         : 0xFE51 (GapScan_enable)
    -Data Length    : 0x06 (6) byte(s)
     Period         : 0x0000 (0)
     Duration       : 0x01F4 (500)
     MaxNumRecords  : 0x0028 (40)
    Dump(Tx):
    0000:01 51 FE 06 00 00 F4 01 28 00                   .Q......(.
    [2] : <Rx> - 03:45:59.207
    Dump(Rx):
    0000:04 FF 06 7F 06 00 51 FE 00                      ......Q..
    [3] : <Rx> - 03:45:59.223
     EventId        : 0x00010000 (65536) (
                      GAP_EVT_SCAN_ENABLED)
    Dump(Rx):
    0000:04 FF 07 13 06 00 00 00 01 00                   ..........
    [4] : <Rx> - 03:45:59.244
    -Data Length    : 0x30 (48) bytes(s)
     EventId        : 0x00400000 (4194304) (
                      GAP_EVT_ADV_REPORT)
     AdvRptEventType: 0x13 (19) (Legacy_ADV_IND_or_Data_Complete)
     AddressType    : 0x01 (1) (ADDRTYPE_RANDOM)
     Address        : 60:CC:5D:74:C9:F9
     PrimaryPHY     : 0x01 (1) (SCANNED_PHY_1M)
     SecondaryPHY   : 0x00 (0) (SCANNED_PHY_NONE)
     AdvSid         : 0xFF (255)
     RSSI           : 0xA2 (162)
     DirectAddrType : 0xFF (255) (ADDRTYPE_NONE)
     DirectAddr     : 00:00:00:00:00:00
     PeriodicAdvInt : 0x0000 (0)
     DataLength     : 0x0011 (17)
     Data           : 02:01:1A:02:0A:07:0A:FF:4C:00:10:05:23:18:C5:30:
                      C1
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 F9 C9 74 5D ..0.....@.....t]
    0010:CC 60 01 00 FF 7F A2 FF 00 00 00 00 00 00 00 00 .`..............
    0020:11 00 02 01 1A 02 0A 07 0A FF 4C 00 10 05 23 18 ..........L...#.
    0030:C5 30 C1                                        .0.
    [5] : <Rx> - 03:45:59.260
    -Data Length    : 0x3E (62) bytes(s)
                      GAP_EVT_ADV_REPORT)
     AdvRptEventType: 0x10 (16) (Legacy_ADV_NONCONN_or_Data_Complete)
     Address        : 10:5B:04:B3:8E:59
     AdvSid         : 0xFF (255)
     RSSI           : 0xA0 (160)
     DataLength     : 0x001F (31)
     Data           : 1E:FF:06:00:01:09:20:02:73:30:AB:F6:EF:9A:0C:CA:
                      D6:CF:6C:A2:A5:3A:6C:8C:38:B8:21:76:D6:80:A0
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 59 8E B3 04 ..>.....@...Y...
    0010:5B 10 01 00 FF 7F A0 FF 00 00 00 00 00 00 00 00 [...............
    0020:1F 00 1E FF 06 00 01 09 20 02 73 30 AB F6 EF 9A ........ .s0....
    0030:0C CA D6 CF 6C A2 A5 3A 6C 8C 38 B8 21 76 D6 80 ....l..:l.8.!v..
    0040:A0                                              .
    [6] : <Rx> - 03:45:59.281
                      GAP_EVT_ADV_REPORT)
     Address        : 37:D6:19:49:7A:54
     AdvSid         : 0xFF (255)
     RSSI           : 0xC0 (192)
     Data           : 1E:FF:06:00:01:09:20:02:83:C9:A8:47:5F:4D:60:B7:
                      9A:42:BE:B5:DE:2F:FC:E3:E5:B7:B4:32:73:34:B0
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 54 7A 49 19 ..>.....@...TzI.
    0010:D6 37 01 00 FF 7F C0 FF 00 00 00 00 00 00 00 00 .7..............
    0020:1F 00 1E FF 06 00 01 09 20 02 83 C9 A8 47 5F 4D ........ ....G_M
    0030:60 B7 9A 42 BE B5 DE 2F FC E3 E5 B7 B4 32 73 34 `..B.../.....2s4
    0040:B0                                              .
    [7] : <Rx> - 03:45:59.296
    -Data Length    : 0x3B (59) bytes(s)
                      GAP_EVT_ADV_REPORT)
     Address        : 57:37:5E:E7:E0:23
     AdvSid         : 0xFF (255)
     RSSI           : 0xA3 (163)
     DataLength     : 0x001C (28)
     Data           : 02:01:06:03:03:F5:FF:14:21:E4:CC:DB:E2:2A:2A:A3:
                      A2:E9:11:99:B4:C0:BB:10:58:00:33:44
    Dump(Rx):
    0000:04 FF 3B 13 06 00 00 00 40 00 13 01 23 E0 E7 5E ..;.....@...#..^
    0010:37 57 01 00 FF 7F A3 FF 00 00 00 00 00 00 00 00 7W..............
    0020:1C 00 02 01 06 03 03 F5 FF 14 21 E4 CC DB E2 2A ..........!....*
    0030:2A A3 A2 E9 11 99 B4 C0 BB 10 58 00 33 44       *.........X.3D
    [8] : <Rx> - 03:45:59.312
                      GAP_EVT_ADV_REPORT)
     Address        : 1F:DC:ED:3C:96:C0
     AdvSid         : 0xFF (255)
     RSSI           : 0xB8 (184)
     Data           : 1E:FF:06:00:01:09:20:02:7F:EE:61:D6:67:54:A7:E4:
                      07:64:B2:41:A7:94:32:4B:1B:EB:D6:53:C6:74:B0
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 C0 96 3C ED ..>.....@.....<.
    0010:DC 1F 01 00 FF 7F B8 FF 00 00 00 00 00 00 00 00 ................
    0020:1F 00 1E FF 06 00 01 09 20 02 7F EE 61 D6 67 54 ........ ...a.gT
    0030:A7 E4 07 64 B2 41 A7 94 32 4B 1B EB D6 53 C6 74 ...d.A..2K...S.t
    0040:B0                                              .
    [9] : <Rx> - 03:45:59.327
    -Data Length    : 0x22 (34) bytes(s)
                      GAP_EVT_ADV_REPORT)
     Address        : 53:11:D0:90:63:9B
     AdvSid         : 0xFF (255)
     RSSI           : 0xA5 (165)
     DataLength     : 0x0003 (3)
     Data           : 02:01:06
    Dump(Rx):
    0000:04 FF 22 13 06 00 00 00 40 00 13 01 9B 63 90 D0 ..".....@....c..
    0010:11 53 01 00 FF 7F A5 FF 00 00 00 00 00 00 00 00 .S..............
    0020:03 00 02 01 06                                  .....
    [10] : <Rx> - 03:45:59.343
                      GAP_EVT_ADV_REPORT)
     Address        : 01:4A:03:C0:F5:74
     AdvSid         : 0xFF (255)
     RSSI           : 0xA6 (166)
     Data           : 1E:FF:06:00:01:09:20:02:E1:E7:95:A4:D5:1C:B6:40:
                      96:3A:32:62:7C:79:FE:FA:69:9B:58:1D:09:81:F4
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 74 F5 C0 03 ..>.....@...t...
    0010:4A 01 01 00 FF 7F A6 FF 00 00 00 00 00 00 00 00 J...............
    0020:1F 00 1E FF 06 00 01 09 20 02 E1 E7 95 A4 D5 1C ........ .......
    0030:B6 40 96 3A 32 62 7C 79 FE FA 69 9B 58 1D 09 81 .@.:2b|y..i.X...
    0040:F4                                              .
    [11] : <Rx> - 03:45:59.359
                      GAP_EVT_ADV_REPORT)
     Address        : 7B:E7:17:C6:A8:9A
     AdvSid         : 0xFF (255)
     RSSI           : 0xA4 (164)
     Data           : 1E:FF:06:00:01:09:20:06:FA:D5:8B:10:E5:09:C5:27:
                      88:91:C7:E1:39:2F:89:D6:BA:D4:DD:2A:B2:D6:E0
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 9A A8 C6 17 ..>.....@.......
    0010:E7 7B 01 00 FF 7F A4 FF 00 00 00 00 00 00 00 00 .{..............
    0020:1F 00 1E FF 06 00 01 09 20 06 FA D5 8B 10 E5 09 ........ .......
    0030:C5 27 88 91 C7 E1 39 2F 89 D6 BA D4 DD 2A B2 D6 .'....9/.....*..
    0040:E0                                              .
    [12] : <Rx> - 03:45:59.375
                      GAP_EVT_ADV_REPORT)
     Address        : 69:EC:BE:26:EA:C6
     AdvSid         : 0xFF (255)
     RSSI           : 0xA1 (161)
     Data           : 02:01:1A:02:0A:07:0A:FF:4C:00:10:05:23:18:36:F8:
                      F2
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 C6 EA 26 BE ..0.....@.....&.
    0010:EC 69 01 00 FF 7F A1 FF 00 00 00 00 00 00 00 00 .i..............
    0030:36 F8 F2                                        6..
    [13] : <Rx> - 03:45:59.421
                      GAP_EVT_ADV_REPORT)
     Address        : 09:A8:D2:17:AA:69
     AdvSid         : 0xFF (255)
     RSSI           : 0xB0 (176)
     Data           : 1E:FF:06:00:01:09:20:02:B1:95:15:F2:33:51:E4:10:
                      D2:61:23:5B:4D:E9:94:93:31:91:11:57:CF:5B:49
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 69 AA 17 D2 ..>.....@...i...
    0010:A8 09 01 00 FF 7F B0 FF 00 00 00 00 00 00 00 00 ................
    0020:1F 00 1E FF 06 00 01 09 20 02 B1 95 15 F2 33 51 ........ .....3Q
    0030:E4 10 D2 61 23 5B 4D E9 94 93 31 91 11 57 CF 5B ...a#[M...1..W.[
    0040:49                                              I
    [14] : <Rx> - 03:45:59.461
                      GAP_EVT_ADV_REPORT)
     Address        : 2D:9B:7D:D0:2B:12
     AdvSid         : 0xFF (255)
     RSSI           : 0xBC (188)
     Data           : 1E:FF:06:00:01:09:20:02:16:41:87:31:E9:F6:BC:41:
                      39:1D:DB:60:E0:DE:2F:EA:EE:B1:98:DE:42:93:02
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 12 2B D0 7D ..>.....@....+.}
    0010:9B 2D 01 00 FF 7F BC FF 00 00 00 00 00 00 00 00 .-..............
    0020:1F 00 1E FF 06 00 01 09 20 02 16 41 87 31 E9 F6 ........ ..A.1..
    0030:BC 41 39 1D DB 60 E0 DE 2F EA EE B1 98 DE 42 93 .A9..`../.....B.
    0040:02                                              .
    [15] : <Rx> - 03:45:59.476
    -Data Length    : 0x31 (49) bytes(s)
                      GAP_EVT_ADV_REPORT)
     Address        : 78:21:34:8E:C2:00
     AdvSid         : 0xFF (255)
     RSSI           : 0xA6 (166)
     DataLength     : 0x0012 (18)
     Data           : 02:01:1A:02:0A:0C:0B:FF:4C:00:10:06:18:1E:9F:61:
                      41:93
    Dump(Rx):
    0000:04 FF 31 13 06 00 00 00 40 00 13 01 00 C2 8E 34 ..1.....@......4
    0010:21 78 01 00 FF 7F A6 FF 00 00 00 00 00 00 00 00 !x..............
    0020:12 00 02 01 1A 02 0A 0C 0B FF 4C 00 10 06 18 1E ..........L.....
    0030:9F 61 41 93                                     .aA.
    [16] : <Rx> - 03:45:59.492
                      GAP_EVT_ADV_REPORT)
     Address        : 2E:94:3E:0C:C7:DF
     AdvSid         : 0xFF (255)
     RSSI           : 0xA4 (164)
     Data           : 1E:FF:06:00:01:09:20:02:45:5C:B1:B3:DA:5F:D5:1E:
                      E2:D3:19:74:16:A2:18:58:3F:7A:43:54:C9:61:CF
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 DF C7 0C 3E ..>.....@......>
    0010:94 2E 01 00 FF 7F A4 FF 00 00 00 00 00 00 00 00 ................
    0020:1F 00 1E FF 06 00 01 09 20 02 45 5C B1 B3 DA 5F ........ .E\..._
    0030:D5 1E E2 D3 19 74 16 A2 18 58 3F 7A 43 54 C9 61 .....t...X?zCT.a
    0040:CF                                              .
    [17] : <Rx> - 03:45:59.508
    -Data Length    : 0x1F (31) bytes(s)
                      GAP_EVT_ADV_REPORT)
     AdvRptEventType: 0x00 (0) (AE_Undir_NC_NS_or_Data_Complete)
     AddressType    : 0x00 (0) (ADDRTYPE_PUBLIC)
     Address        : F8:8A:5E:2D:8C:BB
     SecondaryPHY   : 0xA1 (161) (Unknown ScanScannedPhy #161)
     AdvSid         : 0x01 (1)
     RSSI           : 0xA0 (160)
     DataLength     : 0x0000 (0)
     Data           :
    Dump(Rx):
    0000:04 FF 1F 13 06 00 00 00 40 00 00 00 BB 8C 2D 5E ........@.....-^
    0010:8A F8 01 A1 01 7F A0 FF 00 00 00 00 00 00 00 00 ................
    0020:00 00                                           ..
    [18] : <Rx> - 03:45:59.746
                      GAP_EVT_ADV_REPORT)
     Address        : 49:BD:75:BF:C1:0B
     AdvSid         : 0xFF (255)
     RSSI           : 0xA3 (163)
     Data           : 02:01:1A:02:0A:07:0A:FF:4C:00:10:05:2F:1C:17:F3:
                      A9
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 0B C1 BF 75 ..0.....@......u
    0010:BD 49 01 00 FF 7F A3 FF 00 00 00 00 00 00 00 00 .I..............
    0020:11 00 02 01 1A 02 0A 07 0A FF 4C 00 10 05 2F 1C ..........L.../.
    0030:17 F3 A9                                        ...
    [19] : <Rx> - 03:45:59.793
                      GAP_EVT_ADV_REPORT)
     Address        : 7F:77:5D:19:CF:6C
     AdvSid         : 0xFF (255)
     RSSI           : 0xAF (175)
     Data           : 02:01:1A:02:0A:18:0A:FF:4C:00:10:05:03:98:63:97:
                      71
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 6C CF 19 5D ..0.....@...l..]
    0010:77 7F 01 00 FF 7F AF FF 00 00 00 00 00 00 00 00 w...............
    0020:11 00 02 01 1A 02 0A 18 0A FF 4C 00 10 05 03 98 ..........L.....
    0030:63 97 71                                        c.q
    [20] : <Rx> - 03:45:59.824
                      GAP_EVT_ADV_REPORT)
     AddressType    : 0x03 (3) (ADDRTYPE_RANDOM_ID)
     Address        : D6:D5:D4:D3:D2:D1
     AdvSid         : 0xFF (255)
     RSSI           : 0xA0 (160)
     Data           : 02:01:06
    Dump(Rx):
    0000:04 FF 22 13 06 00 00 00 40 00 13 03 D1 D2 D3 D4 ..".....@.......
    0010:D5 D6 01 00 FF 7F A0 FF 00 00 00 00 00 00 00 00 ................
    [21] : <Rx> - 03:46:04.210
     EventId        : 0x00020000 (131072) (
                      GAP_EVT_SCAN_DISABLED)
     EndReason      : 0x01 (1) (SCAN_END_REASON_DUR_EXP)
     NumberOfReports: 0x11 (17)
    Dump(Rx):
    0000:04 FF 09 13 06 00 00 00 02 00 01 11             ............
    [1] : <Tx> - 03:44:57.272
                      GAP_ADV_CHAN_37
                      GAP_ADV_CHAN_38
                      GAP_ADV_CHAN_39)
     SID            : 0x01 (1)
    Dump(Tx):
    [2] : <Rx> - 03:44:57.459
     Handle         : 0x00 (0)
    Dump(Rx):
    [3] : <Tx> - 03:45:06.455
    Dump(Tx):
    [4] : <Rx> - 03:45:06.486
    Dump(Rx):
    [5] : <Tx> - 03:45:08.905
                      Peripheral)
    Dump(Tx):
    [6] : <Rx> - 03:45:08.929
    Dump(Rx):
    [7] : <Rx> - 03:45:08.945
     CSRK           : EF:C2:BB:C7:47:D8:98:BB:3B:77:A3:27:0C:AE:F5:E8
    Dump(Rx):
    0010:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EF ................
    0020:C2 BB C7 47 D8 98 BB 3B 77 A3 27 0C AE F5 E8    ...G...;w.'....
    [8] : <Tx> - 03:45:15.256
                      GAP_ADV_CHAN_37
                      GAP_ADV_CHAN_38
                      GAP_ADV_CHAN_39)
     SID            : 0x01 (1)
    Dump(Tx):
    [9] : <Rx> - 03:45:15.307
     Handle         : 0x00 (0)
    Dump(Rx):
    [10] : <Tx> - 03:45:19.985
     Handle         : 0x00 (0)
    Dump(Tx):
    [11] : <Rx> - 03:45:20.020
    Dump(Rx):
    [12] : <Tx> - 03:45:26.232
     Handle         : 0x00 (0)
    Dump(Tx):
    [13] : <Rx> - 03:45:26.251
    Dump(Rx):
    [14] : <Rx> - 03:45:26.266
    Dump(Rx):
    [15] : <Tx> - 03:45:29.476
     Handle         : 0x00 (0)
    Dump(Tx):
    [16] : <Rx> - 03:45:29.501
    Dump(Rx):
    [17] : <Rx> - 03:45:29.526
    Dump(Rx):
    [18] : <Tx> - 03:45:33.426
     Handle         : 0x00 (0)
     PayloadLength  : 0x03 (3)
     Data           : 00:01:02
    Dump(Tx):
    0000:01 15 FE 06 00 03 03 00 01 02                   ..........
    [19] : <Rx> - 03:45:33.453
    Dump(Rx):
    [20] : <Rx> - 03:45:33.469
    Dump(Rx):
    [21] : <Tx> - 03:45:35.196
     Enable         : 0x01 (1)
     Handle         : 0x00 (0)
    Dump(Tx):
    [22] : <Rx> - 03:45:35.236
    Dump(Rx):
    [23] : <Rx> - 03:45:35.266
    Dump(Rx):
    I've also provided the sniffer log as a file attachment.
    8037.Trace.zip
    Got it. Thank you! I will review the logs on Monday and get back to you with regards to next steps.
    Jan
    I have looked over the log and it does seem that the device is performing periodic advertising. The ADV_EXT_IND and AUX_ADV_IND packets are transmitted as is shown in the Periodic Advertising section of the user's guide. Have you followed the process detailed in the Synchronize with a Periodic Advertising Train section of the User's Guide for the central side of this? It details what is needed in order to see the periodic advertisements on the scanning side of the connection.
    Jan
    I've been trying to follow the steps mentioned in the page referenced by you, but I'm receiving a bleInvalidRange error when I'm trying to run GapScan_SetPeriodicAdvReceiveEnable. (see SyncWIthPeriodicAdvTrain.txt BTool log)
    [1] : <Info> - 01:43:32.854
    Port opened at 6/29/2022 1:43:32 PM
    [2] : <Tx> - 01:43:32.991
    Dump(Tx):
    [3] : <Rx> - 01:43:33.242
    Dump(Rx):
    [4] : <Tx> - 01:43:33.805
     ProfileRole    : 0x08 (8) (
                      Central)
    Dump(Tx):
    0000:01 00 FE 08 08 00 00 00 00 00 00 00             ............
    [5] : <Rx> - 01:43:33.973
    Dump(Rx):
    [6] : <Rx> - 01:43:33.989
     DevAddr        : F8:8A:5E:2D:8A:BD
     CSRK           : B1:A0:B9:FC:AE:3B:D6:1D:6E:8D:CB:17:E8:88:5E:05
    Dump(Rx):
    0000:04 FF 2C 00 06 00 BD 8A 2D 5E 8A F8 FF 00 05 00 ..,.....-^......
    0010:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 ................
    0020:A0 B9 FC AE 3B D6 1D 6E 8D CB 17 E8 88 5E 05    ....;..n.....^.
    [7] : <Tx> - 01:43:34.025
    -OpCode         : 0xFE61 (GapInit_getPhyParam)
     PHY            : 0x01 (1) (INIT_PHY_1M)
     ParamId        : 0x02 (2) (INIT_PHYPARAM_CONN_INT_MIN)
    Dump(Tx):
    0000:01 61 FE 02 01 02                               .a....
    [8] : <Tx> - 01:43:34.057
     ParamId        : 0x03 (3) (INIT_PHYPARAM_CONN_INT_MAX)
    Dump(Tx):
    0000:01 61 FE 02 01 03                               .a....
    [9] : <Tx> - 01:43:34.073
     ParamId        : 0x04 (4) (INIT_PHYPARAM_CONN_LATENCY)
    Dump(Tx):
    0000:01 61 FE 02 01 04                               .a....
    [10] : <Tx> - 01:43:34.092
     ParamId        : 0x05 (5) (INIT_PHYPARAM_SUP_TIMEOUT)
    Dump(Tx):
    0000:01 61 FE 02 01 05                               .a....
    [11] : <Rx> - 01:43:34.092
     DataLength     : 0x03 (3)
     MinConnectInter: 0x0050 (80)
    Dump(Rx):
    0000:04 FF 09 7F 06 00 61 FE 03 02 50 00             ......a...P.
    [12] : <Rx> - 01:43:34.107
     MaxConnectInter: 0x0050 (80)
    Dump(Rx):
    0000:04 FF 09 7F 06 00 61 FE 03 03 50 00             ......a...P.
    [13] : <Rx> - 01:43:34.203
     ConnectLatency : 0x0000 (0)
    Dump(Rx):
    0000:04 FF 09 7F 06 00 61 FE 03 04 00 00             ......a.....
    [14] : <Rx> - 01:43:34.227
     SuperTimeout   : 0x07D0 (2000)
    Dump(Rx):
    0000:04 FF 09 7F 06 00 61 FE 03 05 D0 07             ......a.....
    [15] : <Tx> - 01:46:36.714
     Period         : 0x0000 (0)
    Dump(Tx):
    [16] : <Rx> - 01:46:36.754
    Dump(Rx):
    [17] : <Rx> - 01:46:36.770
    Dump(Rx):
    [18] : <Rx> - 01:46:36.792
                      GAP_EVT_ADV_REPORT)
     Address        : 6A:1D:63:1B:E5:52
     AdvSid         : 0xFF (255)
     RSSI           : 0xB7 (183)
     Data           : 02:01:06
    Dump(Rx):
    0000:04 FF 22 13 06 00 00 00 40 00 13 01 52 E5 1B 63 ..".....@...R..c
    0010:1D 6A 01 00 FF 7F B7 FF 00 00 00 00 00 00 00 00 .j..............
    [19] : <Rx> - 01:46:36.809
                      GAP_EVT_ADV_REPORT)
     Address        : 52:D6:5D:C8:16:29
     AdvSid         : 0xFF (255)
     RSSI           : 0xA6 (166)
     Data           : 02:01:1A:02:0A:08:0A:FF:4C:00:10:05:23:18:F1:FD:
                      88
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 29 16 C8 5D ..0.....@...)..]
    0010:D6 52 01 00 FF 7F A6 FF 00 00 00 00 00 00 00 00 .R..............
    0020:11 00 02 01 1A 02 0A 08 0A FF 4C 00 10 05 23 18 ..........L...#.
    0030:F1 FD 88                                        ...
    [20] : <Rx> - 01:46:36.830
                      GAP_EVT_ADV_REPORT)
     Address        : 7E:0E:B0:C7:E5:E7
     AdvSid         : 0xFF (255)
     RSSI           : 0xC4 (196)
     Data           : 02:01:06
    Dump(Rx):
    0000:04 FF 22 13 06 00 00 00 40 00 13 01 E7 E5 C7 B0 ..".....@.......
    0010:0E 7E 01 00 FF 7F C4 FF 00 00 00 00 00 00 00 00 .~..............
    [21] : <Rx> - 01:46:36.846
                      GAP_EVT_ADV_REPORT)
     Address        : 1B:46:EC:F9:3E:53
     AdvSid         : 0xFF (255)
     RSSI           : 0xB1 (177)
     Data           : 1E:FF:06:00:01:09:20:02:E0:AC:15:FE:8E:B4:9A:BF:
                      F4:3C:D2:81:C4:6A:B8:04:06:32:85:63:D7:7A:92
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 53 3E F9 EC ..>.....@...S>..
    0010:46 1B 01 00 FF 7F B1 FF 00 00 00 00 00 00 00 00 F...............
    0020:1F 00 1E FF 06 00 01 09 20 02 E0 AC 15 FE 8E B4 ........ .......
    0030:9A BF F4 3C D2 81 C4 6A B8 04 06 32 85 63 D7 7A ...<...j...2.c.z
    0040:92                                              .
    [22] : <Rx> - 01:46:36.869
                      GAP_EVT_ADV_REPORT)
     Address        : 5A:F6:AF:27:83:B5
     AdvSid         : 0xFF (255)
     RSSI           : 0xAB (171)
     Data           : 02:01:1A:02:0A:07:0A:FF:4C:00:10:05:23:18:70:09:
                      68
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 B5 83 27 AF ..0.....@.....'.
    0010:F6 5A 01 00 FF 7F AB FF 00 00 00 00 00 00 00 00 .Z..............
    0030:70 09 68                                        p.h
    [23] : <Rx> - 01:46:36.885
                      GAP_EVT_ADV_REPORT)
     Address        : 47:21:7D:55:5F:7B
     AdvSid         : 0xFF (255)
     RSSI           : 0xB1 (177)
     Data           : 1E:FF:06:00:01:09:20:02:1A:20:0B:6F:65:B5:69:0B:
                      26:34:BD:F9:DE:DE:31:10:BA:02:01:90:76:6C:5F
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 7B 5F 55 7D ..>.....@...{_U}
    0010:21 47 01 00 FF 7F B1 FF 00 00 00 00 00 00 00 00 !G..............
    0020:1F 00 1E FF 06 00 01 09 20 02 1A 20 0B 6F 65 B5 ........ .. .oe.
    0030:69 0B 26 34 BD F9 DE DE 31 10 BA 02 01 90 76 6C i.&4....1.....vl
    0040:5F                                              _
    [24] : <Rx> - 01:46:36.905
                      GAP_EVT_ADV_REPORT)
     Address        : 00:54:AA:AA:0C:95
     AdvSid         : 0xFF (255)
     RSSI           : 0xC5 (197)
     Data           : 1E:FF:06:00:01:09:20:02:FC:80:08:E9:9A:8D:9C:1F:
                      7B:13:5C:00:0A:C4:E0:7F:DE:F9:C1:AB:9B:59:4B
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 95 0C AA AA ..>.....@.......
    0010:54 00 01 00 FF 7F C5 FF 00 00 00 00 00 00 00 00 T...............
    0020:1F 00 1E FF 06 00 01 09 20 02 FC 80 08 E9 9A 8D ........ .......
    0030:9C 1F 7B 13 5C 00 0A C4 E0 7F DE F9 C1 AB 9B 59 ..{.\..........Y
    0040:4B                                              K
    [25] : <Rx> - 01:46:36.921
    -Data Length    : 0x3A (58) bytes(s)
                      GAP_EVT_ADV_REPORT)
     Address        : 3F:82:A4:66:EA:D8
     AdvSid         : 0xFF (255)
     RSSI           : 0xBD (189)
     DataLength     : 0x001B (27)
     Data           : 02:01:1A:17:FF:4C:00:05:12:00:00:00:00:00:00:00:
                      00:01:1F:4E:F6:F8:5F:F5:C6:41:00
    Dump(Rx):
    0000:04 FF 3A 13 06 00 00 00 40 00 10 01 D8 EA 66 A4 ..:.....@.....f.
    0010:82 3F 01 00 FF 7F BD FF 00 00 00 00 00 00 00 00 .?..............
    0020:1B 00 02 01 1A 17 FF 4C 00 05 12 00 00 00 00 00 .......L........
    0030:00 00 00 01 1F 4E F6 F8 5F F5 C6 41 00          .....N.._..A.
    [26] : <Rx> - 01:46:36.936
                      GAP_EVT_ADV_REPORT)
     Address        : 7A:B1:BF:DE:5C:C3
     AdvSid         : 0xFF (255)
     RSSI           : 0xBE (190)
     Data           : 02:01:1A:02:0A:08:0A:FF:4C:00:10:05:33:18:70:F0:
                      2A
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 C3 5C DE BF ..0.....@....\..
    0010:B1 7A 01 00 FF 7F BE FF 00 00 00 00 00 00 00 00 .z..............
    0020:11 00 02 01 1A 02 0A 08 0A FF 4C 00 10 05 33 18 ..........L...3.
    0030:70 F0 2A                                        p.*
    [27] : <Rx> - 01:46:36.952
    -Data Length    : 0x3C (60) bytes(s)
                      GAP_EVT_ADV_REPORT)
     Address        : 6B:95:99:83:B8:67
     AdvSid         : 0xFF (255)
     RSSI           : 0xB1 (177)
     DataLength     : 0x001D (29)
     Data           : 02:01:1A:07:03:0F:18:0A:18:FF:FE:11:09:4A:61:62:
                      72:61:20:45:76:6F:6C:76:65:32:20:36:35
    Dump(Rx):
    0000:04 FF 3C 13 06 00 00 00 40 00 13 01 67 B8 83 99 ..<.....@...g...
    0010:95 6B 01 00 FF 7F B1 FF 00 00 00 00 00 00 00 00 .k..............
    0020:1D 00 02 01 1A 07 03 0F 18 0A 18 FF FE 11 09 4A ...............J
    0030:61 62 72 61 20 45 76 6F 6C 76 65 32 20 36 35    abra Evolve2 65
    [28] : <Rx> - 01:46:36.972
                      GAP_EVT_ADV_REPORT)
     Address        : 05:A7:83:50:7C:F6
     AdvSid         : 0xFF (255)
     RSSI           : 0xB5 (181)
     Data           : 1E:FF:06:00:01:09:20:02:E1:DC:A3:BF:7E:DD:AE:17:
                      D8:EA:82:1A:C8:F0:B5:B5:C4:1F:2C:5B:AF:2F:B6
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 F6 7C 50 83 ..>.....@....|P.
    0010:A7 05 01 00 FF 7F B5 FF 00 00 00 00 00 00 00 00 ................
    0020:1F 00 1E FF 06 00 01 09 20 02 E1 DC A3 BF 7E DD ........ .....~.
    0030:AE 17 D8 EA 82 1A C8 F0 B5 B5 C4 1F 2C 5B AF 2F ............,[./
    0040:B6                                              .
    [29] : <Rx> - 01:46:36.987
                      GAP_EVT_ADV_REPORT)
     Address        : 36:16:8E:33:79:D7
     AdvSid         : 0xFF (255)
     RSSI           : 0xAC (172)
     Data           : 1E:FF:06:00:01:09:20:02:DF:71:B9:07:55:75:C2:83:
                      7E:AE:00:25:A0:2A:55:61:0B:89:6D:9F:AF:A6:85
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 D7 79 33 8E ..>.....@....y3.
    0010:16 36 01 00 FF 7F AC FF 00 00 00 00 00 00 00 00 .6..............
    0020:1F 00 1E FF 06 00 01 09 20 02 DF 71 B9 07 55 75 ........ ..q..Uu
    0030:C2 83 7E AE 00 25 A0 2A 55 61 0B 89 6D 9F AF A6 ..~..%.*Ua..m...
    0040:85                                              .
    [30] : <Rx> - 01:46:37.015
                      GAP_EVT_ADV_REPORT)
     Address        : 73:96:00:36:9B:30
     AdvSid         : 0xFF (255)
     RSSI           : 0xC2 (194)
     Data           : 1E:FF:06:00:01:09:20:02:C1:2A:24:7E:67:97:4D:59:
                      87:A5:D0:1F:72:4F:02:DB:7E:96:BE:B9:8A:24:F5
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 30 9B 36 00 ..>.....@...0.6.
    0010:96 73 01 00 FF 7F C2 FF 00 00 00 00 00 00 00 00 .s..............
    0020:1F 00 1E FF 06 00 01 09 20 02 C1 2A 24 7E 67 97 ........ ..*$~g.
    0030:4D 59 87 A5 D0 1F 72 4F 02 DB 7E 96 BE B9 8A 24 MY....rO..~....$
    0040:F5                                              .
    [31] : <Rx> - 01:46:37.030
    -Data Length    : 0x29 (41) bytes(s)
                      GAP_EVT_ADV_REPORT)
     SecondaryPHY   : 0x3C (60) (Unknown ScanScannedPhy #60)
     AdvSid         : 0x01 (1)
     RSSI           : 0x08 (8)
     DataLength     : 0x000A (10)
     Data           : 92:11:A0:00:FF:FF:FF:FF:BF:91
    Dump(Rx):
    0000:04 FF 29 13 06 00 00 00 40 00 00 00 BB 8C 2D 5E ..).....@.....-^
    0010:8A F8 01 3C 01 7F 08 FF 00 00 00 00 00 00 00 00 ...<............
    0020:0A 00 92 11 A0 00 FF FF FF FF BF 91             ............
    [32] : <Rx> - 01:46:37.050
                      GAP_EVT_ADV_REPORT)
     Address        : 8C:79:F5:21:F3:BA
     AdvSid         : 0xFF (255)
     RSSI           : 0xAF (175)
     Data           : 1B:FF:75:00:42:04:01:80:60:8C:79:F5:21:F3:BA:8E:
                      79:F5:21:F3:B9:01:00:00:00:00:00:00
    Dump(Rx):
    0000:04 FF 3B 13 06 00 00 00 40 00 10 00 BA F3 21 F5 ..;.....@.....!.
    0010:79 8C 01 00 FF 7F AF FF 00 00 00 00 00 00 00 00 y...............
    0020:1C 00 1B FF 75 00 42 04 01 80 60 8C 79 F5 21 F3 ....u.B...`.y.!.
    0030:BA 8E 79 F5 21 F3 B9 01 00 00 00 00 00 00       ..y.!.........
    [33] : <Rx> - 01:46:37.066
                      GAP_EVT_ADV_REPORT)
     Address        : 67:71:83:71:5C:D4
     AdvSid         : 0xFF (255)
     RSSI           : 0xA9 (169)
     Data           : 1E:FF:06:00:01:09:20:02:A1:30:43:23:74:47:B4:6D:
                      2D:46:18:64:DF:32:38:35:C4:7E:0C:BF:6C:61:96
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 D4 5C 71 83 ..>.....@....\q.
    0010:71 67 01 00 FF 7F A9 FF 00 00 00 00 00 00 00 00 qg..............
    0020:1F 00 1E FF 06 00 01 09 20 02 A1 30 43 23 74 47 ........ ..0C#tG
    0030:B4 6D 2D 46 18 64 DF 32 38 35 C4 7E 0C BF 6C 61 .m-F.d.285.~..la
    0040:96                                              .
    [34] : <Rx> - 01:46:37.086
                      GAP_EVT_ADV_REPORT)
     Address        : 7A:1F:1D:F5:9A:C7
     AdvSid         : 0xFF (255)
     RSSI           : 0xBE (190)
     Data           : 1E:FF:06:00:01:09:20:02:11:16:25:FD:D6:24:BC:79:
                      23:A1:DD:85:64:85:71:62:FB:10:DF:B0:77:26:35
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 C7 9A F5 1D ..>.....@.......
    0010:1F 7A 01 00 FF 7F BE FF 00 00 00 00 00 00 00 00 .z..............
    0020:1F 00 1E FF 06 00 01 09 20 02 11 16 25 FD D6 24 ........ ...%..$
    0030:BC 79 23 A1 DD 85 64 85 71 62 FB 10 DF B0 77 26 .y#...d.qb....w&
    0040:35                                              5
    [35] : <Rx> - 01:46:41.776
    Dump(Rx):
    [36] : <Tx> - 01:51:52.173
    -OpCode         : 0xFE1B (GapScan_AddDeviceToPeriodicAdvList)
     advAddrType    : 0x00 (0) (PEER_ADDRTYPE_PUBLIC_OR_PUBLIC_ID)
     advAddress     : F8:8A:5E:2D:8C:BB
     advSID         : 0x01 (1)
    Dump(Tx):
    0000:01 1B FE 08 00 BB 8C 2D 5E 8A F8 01             .......-^...
    [37] : <Rx> - 01:51:52.197
    Dump(Rx):
    0000:04 FF 06 7F 06 00 1B FE 00                      .........
    [38] : <Tx> - 01:52:38.278
    -OpCode         : 0xFE17 (GapScan_PeriodicAdvCreateSync)
    -Data Length    : 0x0E (14) byte(s)
     advSID         : 0x00 (0)
     options        : 0x03 (3) (
                      USE_PERIODIC_ADVERTISER_LIST
                      DISABLE_PERIODIC_ADVERTISING_REPORT)
     advAddress     : 00:00:00:00:00:00
     skip           : 0x0000 (0)
     syncTimeout    : 0x03E8 (1000)
     syncCteType    : 0x00 (0) (
                      PeriodicAdvSyncCteTypes Bit Mask Is Not Set)
    Dump(Tx):
    0000:01 17 FE 0E 00 03 00 00 00 00 00 00 00 00 00 E8 ................
    0010:03 00                                           ..
    [39] : <Rx> - 01:52:38.332
    Dump(Rx):
    0000:04 FF 06 7F 06 00 17 FE 00                      .........
    [40] : <Tx> - 01:52:47.166
     Period         : 0x0000 (0)
     MaxNumRecords  : 0x0000 (0)
    Dump(Tx):
    0000:01 51 FE 06 00 00 F4 01 00 00                   .Q........
    [41] : <Rx> - 01:52:47.205
    Dump(Rx):
    [42] : <Rx> - 01:52:47.221
    Dump(Rx):
    [43] : <Rx> - 01:52:47.246
                      GAP_EVT_ADV_REPORT)
     Address        : 68:FA:2A:C1:04:F8
     AdvSid         : 0xFF (255)
     RSSI           : 0xA6 (166)
     Data           : 02:01:1A:02:0A:0C:0B:FF:4C:00:10:06:4D:1E:05:B5:
                      E6:08
    Dump(Rx):
    0000:04 FF 31 13 06 00 00 00 40 00 13 01 F8 04 C1 2A ..1.....@......*
    0010:FA 68 01 00 FF 7F A6 FF 00 00 00 00 00 00 00 00 .h..............
    0020:12 00 02 01 1A 02 0A 0C 0B FF 4C 00 10 06 4D 1E ..........L...M.
    0030:05 B5 E6 08                                     ....
    [44] : <Rx> - 01:52:47.274
                      GAP_EVT_ADV_REPORT)
     Address        : 73:1E:B7:D2:B3:64
     AdvSid         : 0xFF (255)
     RSSI           : 0xB7 (183)
     Data           : 02:01:1A:02:0A:0C:0B:FF:4C:00:10:06:1A:1E:13:B9:
                      83:E9
    Dump(Rx):
    0000:04 FF 31 13 06 00 00 00 40 00 13 01 64 B3 D2 B7 ..1.....@...d...
    0010:1E 73 01 00 FF 7F B7 FF 00 00 00 00 00 00 00 00 .s..............
    0020:12 00 02 01 1A 02 0A 0C 0B FF 4C 00 10 06 1A 1E ..........L.....
    0030:13 B9 83 E9                                     ....
    [45] : <Rx> - 01:52:47.290
                      GAP_EVT_ADV_REPORT)
     Address        : 65:A1:6A:FB:BD:4F
     AdvSid         : 0xFF (255)
     RSSI           : 0xA8 (168)
     Data           : 02:01:1A:02:0A:0C:0B:FF:4C:00:10:06:07:1A:7B:07:
                      41:BA
    Dump(Rx):
    0000:04 FF 31 13 06 00 00 00 40 00 13 01 4F BD FB 6A ..1.....@...O..j
    0010:A1 65 01 00 FF 7F A8 FF 00 00 00 00 00 00 00 00 .e..............
    0020:12 00 02 01 1A 02 0A 0C 0B FF 4C 00 10 06 07 1A ..........L.....
    0030:7B 07 41 BA                                     {.A.
    [46] : <Rx> - 01:52:47.310
                      GAP_EVT_ADV_REPORT)
     Address        : 3D:32:F1:87:96:54
     AdvSid         : 0xFF (255)
     RSSI           : 0xC7 (199)
     Data           : 1E:FF:06:00:01:09:20:02:27:F5:88:FE:F2:D7:BD:A5:
                      0D:39:B0:0F:92:1E:AA:DA:6F:60:98:33:F8:D2:FB
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 54 96 87 F1 ..>.....@...T...
    0010:32 3D 01 00 FF 7F C7 FF 00 00 00 00 00 00 00 00 2=..............
    0020:1F 00 1E FF 06 00 01 09 20 02 27 F5 88 FE F2 D7 ........ .'.....
    0030:BD A5 0D 39 B0 0F 92 1E AA DA 6F 60 98 33 F8 D2 ...9......o`.3..
    0040:FB                                              .
    [47] : <Rx> - 01:52:47.325
                      GAP_EVT_ADV_REPORT)
     Address        : 18:03:BB:E1:B2:ED
     AdvSid         : 0xFF (255)
     RSSI           : 0xB7 (183)
     Data           : 1E:FF:06:00:01:09:20:02:4B:F5:80:39:66:7F:B2:7E:
                      65:94:11:05:F3:8F:58:63:0E:67:11:42:1C:BE:B6
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 ED B2 E1 BB ..>.....@.......
    0010:03 18 01 00 FF 7F B7 FF 00 00 00 00 00 00 00 00 ................
    0020:1F 00 1E FF 06 00 01 09 20 02 4B F5 80 39 66 7F ........ .K..9f.
    0030:B2 7E 65 94 11 05 F3 8F 58 63 0E 67 11 42 1C BE .~e.....Xc.g.B..
    0040:B6                                              .
    [48] : <Rx> - 01:52:47.346
                      GAP_EVT_ADV_REPORT)
     AdvSid         : 0xFF (255)
     RSSI           : 0xAF (175)
    Dump(Rx):
    0010:16 36 01 00 FF 7F AF FF 00 00 00 00 00 00 00 00 .6..............
    0040:85                                              .
    [49] : <Rx> - 01:52:47.362
                      GAP_EVT_ADV_REPORT)
     AdvSid         : 0xFF (255)
     RSSI           : 0xA8 (168)
    Dump(Rx):
    0010:71 67 01 00 FF 7F A8 FF 00 00 00 00 00 00 00 00 qg..............
    0040:96                                              .
    [50] : <Rx> - 01:52:47.382
                      GAP_EVT_ADV_REPORT)
     Address        : 6D:EA:E4:61:7E:80
     AdvSid         : 0xFF (255)
     RSSI           : 0xB4 (180)
     Data           : 02:01:1A:02:0A:0C:0B:FF:4C:00:10:06:48:1E:4B:D2:
                      01:C6
    Dump(Rx):
    0000:04 FF 31 13 06 00 00 00 40 00 13 01 80 7E 61 E4 ..1.....@....~a.
    0010:EA 6D 01 00 FF 7F B4 FF 00 00 00 00 00 00 00 00 .m..............
    0020:12 00 02 01 1A 02 0A 0C 0B FF 4C 00 10 06 48 1E ..........L...H.
    0030:4B D2 01 C6                                     K...
    [51] : <Rx> - 01:52:47.397
                      GAP_EVT_ADV_REPORT)
     Address        : 6F:D7:62:87:A8:53
     AdvSid         : 0xFF (255)
     RSSI           : 0xB7 (183)
     Data           : 02:01:06
    Dump(Rx):
    0000:04 FF 22 13 06 00 00 00 40 00 13 01 53 A8 87 62 ..".....@...S..b
    0010:D7 6F 01 00 FF 7F B7 FF 00 00 00 00 00 00 00 00 .o..............
    [52] : <Rx> - 01:52:47.418
                      GAP_EVT_ADV_REPORT)
     Address        : 43:C3:4C:AB:A7:02
     AdvSid         : 0xFF (255)
     RSSI           : 0xB5 (181)
     Data           : 02:01:1A:02:0A:06:0A:FF:4C:00:10:05:23:18:E0:05:
                      95
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 02 A7 AB 4C ..0.....@......L
    0010:C3 43 01 00 FF 7F B5 FF 00 00 00 00 00 00 00 00 .C..............
    0020:11 00 02 01 1A 02 0A 06 0A FF 4C 00 10 05 23 18 ..........L...#.
    0030:E0 05 95                                        ...
    [53] : <Rx> - 01:52:47.433
                      GAP_EVT_ADV_REPORT)
     Address        : 72:2B:DD:37:F4:55
     AdvSid         : 0xFF (255)
     RSSI           : 0xAE (174)
     Data           : 02:01:1A:02:0A:08:0A:FF:4C:00:10:05:25:1C:EF:16:
                      81
    Dump(Rx):
    0000:04 FF 30 13 06 00 00 00 40 00 13 01 55 F4 37 DD ..0.....@...U.7.
    0010:2B 72 01 00 FF 7F AE FF 00 00 00 00 00 00 00 00 +r..............
    0020:11 00 02 01 1A 02 0A 08 0A FF 4C 00 10 05 25 1C ..........L...%.
    0030:EF 16 81                                        ...
    [54] : <Rx> - 01:52:47.454
                      GAP_EVT_ADV_REPORT)
     Address        : 73:F3:17:D4:A3:09
     AdvSid         : 0xFF (255)
     RSSI           : 0xA5 (165)
     Data           : 02:01:1A:02:0A:08:0B:FF:4C:00:10:06:29:1A:D3:D3:
                      E2:83
    Dump(Rx):
    0000:04 FF 31 13 06 00 00 00 40 00 13 01 09 A3 D4 17 ..1.....@.......
    0010:F3 73 01 00 FF 7F A5 FF 00 00 00 00 00 00 00 00 .s..............
    0020:12 00 02 01 1A 02 0A 08 0B FF 4C 00 10 06 29 1A ..........L...).
    0030:D3 D3 E2 83                                     ....
    [55] : <Rx> - 01:52:47.475
                      GAP_EVT_ADV_REPORT)
     AdvSid         : 0xFF (255)
     RSSI           : 0xC1 (193)
     Data           : 02:01:06
    Dump(Rx):
    0010:0E 7E 01 00 FF 7F C1 FF 00 00 00 00 00 00 00 00 .~..............
    [56] : <Rx> - 01:52:47.491
                      GAP_EVT_ADV_REPORT)
     Address        : 3F:47:F4:15:1B:90
     AdvSid         : 0xFF (255)
     RSSI           : 0xAD (173)
     Data           : 1E:FF:06:00:01:09:20:02:46:E5:A8:36:BD:19:2A:E1:
                      D3:8D:C6:69:FC:73:19:3F:31:29:E0:BD:15:7A:6F
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 90 1B 15 F4 ..>.....@.......
    0010:47 3F 01 00 FF 7F AD FF 00 00 00 00 00 00 00 00 G?..............
    0020:1F 00 1E FF 06 00 01 09 20 02 46 E5 A8 36 BD 19 ........ .F..6..
    0030:2A E1 D3 8D C6 69 FC 73 19 3F 31 29 E0 BD 15 7A *....i.s.?1)...z
    0040:6F                                              o
    [57] : <Rx> - 01:52:47.538
                      GAP_EVT_ADV_REPORT)
     AdvSid         : 0xFF (255)
     RSSI           : 0xA4 (164)
    Dump(Rx):
    0010:21 47 01 00 FF 7F A4 FF 00 00 00 00 00 00 00 00 !G..............
    0040:5F                                              _
    [58] : <Rx> - 01:52:47.580
                      GAP_EVT_ADV_REPORT)
     Address        : 2D:EA:FB:DE:21:D8
     AdvSid         : 0xFF (255)
     RSSI           : 0xA6 (166)
     Data           : 1E:FF:06:00:01:09:20:02:B6:1E:47:1F:71:94:F2:0F:
                      5C:C2:2B:69:D4:71:F2:D7:0B:1F:E9:B1:D9:F8:63
    Dump(Rx):
    0000:04 FF 3E 13 06 00 00 00 40 00 10 01 D8 21 DE FB ..>.....@....!..
    0010:EA 2D 01 00 FF 7F A6 FF 00 00 00 00 00 00 00 00 .-..............
    0020:1F 00 1E FF 06 00 01 09 20 02 B6 1E 47 1F 71 94 ........ ...G.q.
    0030:F2 0F 5C C2 2B 69 D4 71 F2 D7 0B 1F E9 B1 D9 F8 ..\.+i.q........
    0040:63                                              c
    [59] : <Rx> - 01:52:47.632
                      GAP_EVT_ADV_REPORT)
     AdvSid         : 0x01 (1)
     RSSI           : 0x08 (8)
     Data           : 00:13:A0:00:FF:FF:FF:FF:BF:91
    Dump(Rx):
    0020:0A 00 00 13 A0 00 FF FF FF FF BF 91             ............
    [60] : <Rx> - 01:52:52.236
     NumberOfReports: 0x00 (0)
    Dump(Rx):
    0000:04 FF 09 13 06 00 00 00 02 00 01 00             ............
    [61] : <Tx> - 01:53:08.229
    -OpCode         : 0xFE1A (GapScan_SetPeriodicAdvReceiveEnable)
    -Data Length    : 0x03 (3) byte(s)
     syncHandle     : 0x0000 (0)
     Enable         : 0x01 (1)
    Dump(Tx):
    0000:01 1A FE 03 00 00 01                            .......
    [62] : <Rx> - 01:53:08.251
     Status         : 0x18 (24) (bleInvalidRange)
    Dump(Rx):
    0000:04 FF 06 7F 06 18 1A FE 00                      .........
    It seems that everytime we did PeriodicAdv, we didn't call GapAdv_LoadData, which may be the actual reason we haven't seen any data (neither through BTool nor through the sniffer). After also enabling GapAdv_LoadData, this is how our packets look like through the sniffer:
    (The "Raw Adv Data" is the data loaded through GapAdv_LoadData). The device is still doing PeriodicAdv. I've also attached the whole Ellisys Bluetooth Analyzer log below.
    5342.Log.zip
    We see data now, but my question is: why do we only see the data sent through LoadData(), if the TI is performing PeriodicAdv? Is this normal? I've also sent a SetPeriodicAdvData command, with some payload of length 4 (bytes), but I'm not able to see it anywhere in my sniffer.
    You can see the peripheral log below:
    [1] : <Tx> - 10:35:31.220
    Dump(Tx):
    [2] : <Rx> - 10:35:31.251
    Dump(Rx):
    [3] : <Tx> - 10:35:37.852
                      Peripheral)
    Dump(Tx):
    [4] : <Rx> - 10:35:37.889
    Dump(Rx):
    [5] : <Rx> - 10:35:37.905
     CSRK           : 7B:D3:C5:95:0B:45:33:E1:BD:78:C3:05:3D:5F:22:E9
    Dump(Rx):
    0010:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 7B ...............{
    0020:D3 C5 95 0B 45 33 E1 BD 78 C3 05 3D 5F 22 E9    ....E3..x..=_".
    [6] : <Tx> - 10:35:54.792
                      GAP_ADV_CHAN_37
                      GAP_ADV_CHAN_38
                      GAP_ADV_CHAN_39)
     SID            : 0x01 (1)
    Dump(Tx):
    [7] : <Rx> - 10:35:54.845
     Handle         : 0x00 (0)
    Dump(Rx):
    [8] : <Tx> - 10:36:24.985
    -OpCode         : 0xFE44 (GapAdv_loadData)
    -Data Length    : 0x1200 (4608) byte(s)
     Handle         : 0x00 (0)
     AdvDataType    : 0x00 (0)
     DataLength     : 0x000E (14)
     AdvData        : 11:22:33:44:11:22:33:44:11:22:33:44:11:22
    Dump(Tx):
    0000:09 44 FE 12 00 00 00 0E 00 11 22 33 44 11 22 33 .D........"3D."3
    0010:44 11 22 33 44 11 22                            D."3D."
    [9] : <Rx> - 10:36:25.016
    Dump(Rx):
    0000:04 FF 06 7F 06 00 44 FE 00                      ......D..
    [10] : <Tx> - 10:36:33.236
     Handle         : 0x00 (0)
    Dump(Tx):
    [11] : <Rx> - 10:36:33.283
    Dump(Rx):
    [12] : <Tx> - 10:36:37.779
     Handle         : 0x00 (0)
    Dump(Tx):
    [13] : <Rx> - 10:36:37.816
    Dump(Rx):
    [14] : <Rx> - 10:36:37.832
    Dump(Rx):
    [15] : <Tx> - 10:38:18.276
     Handle         : 0x00 (0)
    Dump(Tx):
    [16] : <Rx> - 10:38:18.328
    Dump(Rx):
    [17] : <Rx> - 10:38:18.344
    Dump(Rx):
    [18] : <Tx> - 10:38:34.570
     Handle         : 0x00 (0)
     Data           : 00:11:22:33
    Dump(Tx):
    [19] : <Rx> - 10:38:34.614
    Dump(Rx):
    [20] : <Rx> - 10:38:34.629
    Dump(Rx):
    [21] : <Tx> - 10:38:44.693
     Enable         : 0x01 (1)
     Handle         : 0x00 (0)
    Dump(Tx):
    [22] : <Rx> - 10:38:44.751
    Dump(Rx):
    [23] : <Rx> - 10:38:44.777
    Dump(Rx):
    Is it normal to only see the data loaded with LoadData through the sniffer?
    My next quesiton would be: how does Synchronizing (with a Periodic Advertising Train) actually help us? What is it really used for? Do we actually need it? Is this a way of actually seeing the PeriodicAdv data sent? (loaded with SetPeriodicAdvData()).
    Thank you.
  • Hi Mario,
    I will look into the logs today and tomorrow and get back to you as soon as possible. In the meantime, I found the following E2E thread in which they were able to successfully implement periodic advertising in btool:
    https://e2e.ti.com/support/wireless-connectivity/bluetooth-group/bluetooth/f/bluetooth-forum/1104062/cc2652r-periodic-advertising-functions-keep-returning-bleinvalidrange
    Can you verify that you have implemented the same function calls and setup as the ones used in that thread?
    Jan
  • Hey Jan,
    It is a small world :). the other thread was started for the same problem. The end result was that we got rid of the bleInvalidRange, but not a complete end to end periodic advertising. (The thread is locked I could not add this info there :( )
  • Hi Mario,
    I looked through your logs and did not see the advertising data on the periodic advertising. However, I was able to get periodic advertising working properly on my end. I have attached a log showcasing this with the relevant packets highlighted:
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/538/host_5F00_test_2D00_PeriodicAdv.btt
    I added the USE_PERIODIC_ADV pre-define to a host_test project. I have attached the zipped project here:
    host_test_periodic_adv.zip
    The commands I used in host_test are shown below:
    [33] : <Tx> - 04:00:43.240
    Dump(Tx):
    [34] : <Rx> - 04:00:43.267
    Dump(Rx):
    [35] : <Tx> - 04:00:55.019
                      Peripheral)
    Dump(Tx):
    [36] : <Rx> - 04:00:55.044
    Dump(Rx):
    [37] : <Rx> - 04:00:55.060
     DevAddr        : 80:6F:B0:31:CC:9D
     CSRK           : 26:A0:DF:05:1C:90:83:AE:35:51:4B:CA:00:A1:C9:07
    Dump(Rx):
    0000:04 FF 2C 00 06 00 9D CC 31 B0 6F 80 FF 00 05 00 ..,.....1.o.....
    0010:00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 26 ...............&
    0020:A0 DF 05 1C 90 83 AE 35 51 4B CA 00 A1 C9 07    .......5QK.....
    [38] : <Tx> - 04:01:13.159
                      GAP_ADV_CHAN_37
                      GAP_ADV_CHAN_38
                      GAP_ADV_CHAN_39)
     SID            : 0x01 (1)
    Dump(Tx):
    [39] : <Rx> - 04:01:13.190
     Handle         : 0x00 (0)
    Dump(Rx):
    [40] : <Tx> - 04:01:46.740
    -Data Length    : 0x1400 (5120) byte(s)
     Handle         : 0x00 (0)
     DataLength     : 0x0010 (16)
     AdvData        : 00:01:02:03:04:05:06:07:08:09:0A:0B:0C:0D:0E:0F
    Dump(Tx):
    0000:09 44 FE 14 00 00 00 10 00 00 01 02 03 04 05 06 .D..............
    0010:07 08 09 0A 0B 0C 0D 0E 0F                      .........
    [41] : <Rx> - 04:01:46.771
    Dump(Rx):
    [42] : <Tx> - 04:02:06.318
     Handle         : 0x00 (0)
    Dump(Tx):
    [43] : <Rx> - 04:02:06.341
    Dump(Rx):
    [44] : <Tx> - 04:02:17.678
     Handle         : 0x00 (0)
    Dump(Tx):
    [45] : <Rx> - 04:02:17.700
    Dump(Rx):
    [46] : <Rx> - 04:02:17.715
    Dump(Rx):
    [47] : <Tx> - 04:02:49.799
     Handle         : 0x00 (0)
    Dump(Tx):
    [48] : <Rx> - 04:02:49.830
    Dump(Rx):
    [49] : <Rx> - 04:02:49.846
    Dump(Rx):
    [50] : <Tx> - 04:03:32.838
     Handle         : 0x00 (0)
     Data           : 00:11:22:33
    Dump(Tx):
    [51] : <Rx> - 04:03:32.868
    Dump(Rx):
    [52] : <Rx> - 04:03:32.884
    Dump(Rx):
    [53] : <Tx> - 04:03:54.239
     Enable         : 0x01 (1)
     Handle         : 0x00 (0)
    Dump(Tx):
    [54] : <Rx> - 04:03:54.264
    Dump(Rx):
    [55] : <Rx> - 04:03:54.279
    Dump(Rx):
    Can you try importing the project and using the same commands I used in my log? Let me know if you have any issues with this.
    Jan
  • Hello Jan. I will take over from Mario for these tests. Unfortunately we need to find a window for that :(. I will come back here once I have the results.
    No worries! If you need any further instructions on how to run the test, then please let me know.
    Jan
