Part Number: LP-CC1312R7
Other Parts Discussed in Thread: CC1312R7, SYSCONFIG
Hi Team,
Currently we have developed solution which includes a custom bootloader and application.
both of the firmware flashed into internal flash, bootloader is flash higher range of memory address till the end of the flash.
As we know TI keeps CCFG at the end of the flash, so the ccfg configuration is the part of bootloader (it's included using ccfg.c).
Now we have situation where we want to modify one of the ccfg setting (CCFG_FORCE_VDDR_HH) once application gets control from custom bootloader.
right now we can not write from application to last sector of flash, because it comes under bootloader flashed memory area which is protected we don't want to give liberty to application to modify bootloder code.
Is there any solution we can use to modify the ccfg config? one extra reload to boot is also acceptable.
Bhasker
