CC2640: GPTimer has been added to the simple_peripheral_oad_offchip project. Consumption current increased to 4 mA.
Part Number: CC2640
hi. GPTimer has been added to the simple_peripheral_oad_offchip project. Consumption current
increased to 4 mA. without timer consumption 27 µA
cc2640
tell me how to fix this and reduce consumption?
  • Share your code for review.
  • Hi Alex,
    The GPTimer is dependent on the MCU system clock which means your device must be actively running for the timer to work, thus standby modes are disabled.  Here are some relevant E2E threads:
    https://e2e.ti.com/f/1/t/1125349
    https://e2e.ti.com/f/1/t/1097321
    You can see inside datasheet Section 5.4 (Power Consumption Summary) how idle/active will require much more power than standby.
    Ryan
    • If we exclude line 700 (GPTimerCC26XX_start(cTimer);), then the current
      consumption 18 uA, and with it 4 mA.
       @file  simple_peripheral.c
       @brief This file contains the Simple Peripheral sample application for use
              with the CC2650 Bluetooth Low Energy Protocol Stack.
       Group: WCS, BTS
       Target Device: cc2640r2
       Copyright (c) 2013-2021, Texas Instruments Incorporated
       All rights reserved.
       Redistribution and use in source and binary forms, with or without
       modification, are permitted provided that the following conditions
       are met:
       *  Redistributions of source code must retain the above copyright
          notice, this list of conditions and the following disclaimer.
       *  Redistributions in binary form must reproduce the above copyright
          notice, this list of conditions and the following disclaimer in the
          documentation and/or other materials provided with the distribution.
       *  Neither the name of Texas Instruments Incorporated nor the names of
          its contributors may be used to endorse or promote products derived
          from this software without specific prior written permission.
       THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
       AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
       THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
       PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
       CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
       EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
       PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
       OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
       WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
       OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
       EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
       * INCLUDES
      #include <string.h>
      #include <ti/sysbios/knl/Task.h>
      #include <ti/sysbios/knl/Clock.h>
      #include <ti/sysbios/knl/Event.h>
      #include <ti/sysbios/knl/Queue.h>
      //#include <ti/display/Display.h>
      #include <ti/drivers/timer/GPTimerCC26XX.h>
      #include <ti/drivers/PIN/PINCC26XX.h>
      #if defined( USE_FPGA ) || defined( DEBUG_SW_TRACE )
      #include <driverlib/ioc.h>
      #endif // USE_FPGA | DEBUG_SW_TRACE
      #include <icall.h>
      #include "util.h"
      #include "att_rsp.h"
      /* This Header file contains all BLE API and icall structure definition */
      #include "icall_ble_api.h"
      #include "devinfoservice.h"
      #include "simple_gatt_profile.h"
      #include "ll_common.h"
      #include "peripheral.h"
      #ifdef USE_RCOSC
      #include "rcosc_calibration.h"
      #endif //USE_RCOSC
      #include "board_key.h"
      #include "BRD/Board.h"
      #include "simple_peripheral_oad_offchip.h"
       * CONSTANTS
      // Advertising interval when device is discoverable (units of 625us, 160=100ms)
      #define DEFAULT_ADVERTISING_INTERVAL          1600
      // General discoverable mode: advertise indefinitely
      #define DEFAULT_DISCOVERABLE_MODE             GAP_ADTYPE_FLAGS_GENERAL
      // Minimum connection interval (units of 1.25ms, 80=100ms) for automatic
      // parameter update request
      #define DEFAULT_DESIRED_MIN_CONN_INTERVAL     80
      // Maximum connection interval (units of 1.25ms, 800=1000ms) for automatic
      #define DEFAULT_DESIRED_MAX_CONN_INTERVAL     800
      // Slave latency to use for automatic parameter update request
      #define DEFAULT_DESIRED_SLAVE_LATENCY         0
      // Supervision timeout value (units of 10ms, 1000=10s) for automatic parameter
      // update request
      #define DEFAULT_DESIRED_CONN_TIMEOUT          1000
      // After the connection is formed, the peripheral waits until the central
      // device asks for its preferred connection parameters
      #define DEFAULT_ENABLE_UPDATE_REQUEST         GAPROLE_LINK_PARAM_UPDATE_WAIT_REMOTE_PARAMS
      // Connection Pause Peripheral time value (in seconds)
      #define DEFAULT_CONN_PAUSE_PERIPHERAL         6
      // How often to perform periodic event (in msec)
      #define SBP_PERIODIC_EVT_PERIOD               5000
      // Application specific event ID for HCI Connection Event End Events
      #define SBP_HCI_CONN_EVT_END_EVT              0x0001
      // Type of Display to open
      #if !defined(Display_DISABLE_ALL)
        #if defined(BOARD_DISPLAY_USE_LCD) && (BOARD_DISPLAY_USE_LCD!=0)
          #define SBP_DISPLAY_TYPE Display_Type_LCD
        #elif defined (BOARD_DISPLAY_USE_UART) && (BOARD_DISPLAY_USE_UART!=0)
          #define SBP_DISPLAY_TYPE Display_Type_UART
        #else // !BOARD_DISPLAY_USE_LCD && !BOARD_DISPLAY_USE_UART
          #define SBP_DISPLAY_TYPE 0 // Option not supported
        #endif // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
      #else // BOARD_DISPLAY_USE_LCD && BOARD_DISPLAY_USE_UART
        #define SBP_DISPLAY_TYPE 0 // No Display
      #endif // !Display_DISABLE_ALL
      // Task configuration
      #define SBP_TASK_PRIORITY                     1
      #ifndef SBP_TASK_STACK_SIZE
      #define SBP_TASK_STACK_SIZE                   644
      #endif
      // Application events
      #define SBP_STATE_CHANGE_EVT                  0x0001
      #define SBP_CHAR_CHANGE_EVT                   0x0002
      #define SBP_PAIRING_STATE_EVT                 0x0004
      #define SBP_PASSCODE_NEEDED_EVT               0x0008
      #define SBP_CONN_EVT                          0x0010
      // Internal Events for RTOS application
      #define SBP_ICALL_EVT                         ICALL_MSG_EVENT_ID // Event_Id_31
      #define SBP_QUEUE_EVT                         UTIL_QUEUE_EVENT_ID // Event_Id_30
      #define SBP_PERIODIC_EVT                      Event_Id_00
      // Bitwise OR of all events to pend on
      #define SBP_ALL_EVENTS                        (SBP_ICALL_EVT        | \
                                                     SBP_QUEUE_EVT        | \
                                                     SBP_PERIODIC_EVT)
      // Set the register cause to the registration bit-mask
      #define CONNECTION_EVENT_REGISTER_BIT_SET(RegisterCause) (connectionEventRegisterCauseBitMap |= RegisterCause )
      // Remove the register cause from the registration bit-mask
      #define CONNECTION_EVENT_REGISTER_BIT_REMOVE(RegisterCause) (connectionEventRegisterCauseBitMap &= (~RegisterCause) )
      // Gets whether the current App is registered to the receive connection events
      #define CONNECTION_EVENT_IS_REGISTERED (connectionEventRegisterCauseBitMap > 0)
      // Gets whether the RegisterCause was registered to recieve connection event
      #define CONNECTION_EVENT_REGISTRATION_CAUSE(RegisterCause) (connectionEventRegisterCauseBitMap & RegisterCause )
       * TYPEDEFS
      // App event passed from profiles.
      typedef struct
        appEvtHdr_t hdr;  // event header.
        uint8_t *pData;  // event data
      } sbpEvt_t;
       * GLOBAL VARIABLES
      // Display Interface
      //Display_Handle dispHandle = NULL;
      GPTimerCC26XX_Handle cTimer;
      static PIN_State timerPinState;
      void ctimerCallback(GPTimerCC26XX_Handle handle, GPTimerCC26XX_IntMask interruptMask);
      PIN_Config GptPinInitTable[] =
       Board_COUNTER | PIN_GPIO_OUTPUT_DIS | PIN_INPUT_EN | PIN_PULLDOWN | PIN_HYSTERESIS,
       PIN_TERMINATE
      PIN_Handle timerPinHandle;
      /* Global memory storage for a PIN_Config table */
      static PIN_State AccelCS_PinState;
      PIN_Config AccelCS_PinInitTable[] =
       Board_SPI_ACCEL_CS | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_DRVSTR_MED,
       PIN_TERMINATE
      //PIN_PUSHPULL
      static const PIN_Config sbpLedPins[] = {
      #ifdef LED_DEBUG
          Board_LED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_DRVSTR_MED,
      #endif
          Board_CTRL_T | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_DRVSTR_MED | PIN_OPENDRAIN, /*����������*/
          Board_SPI_ACC_EN | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_DRVSTR_MED | PIN_OPENDRAIN, /*SPI*/
      // IRLM Board_ADC_T_EN | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_DRVSTR_MED | PIN_OPENDRAIN, /*�������������*/
          Board_ADC_T_EN | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_DRVSTR_MED, /*�������������*/
          PIN_TERMINATE
      PIN_State  sbpLedState;
       * LOCAL VARIABLES
      // Entity ID globally used to check for source and/or destination of messages
      static ICall_EntityID selfEntity;
      // Event globally used to post local events and pend on system and
      // local events.
      static ICall_SyncHandle syncEvent;
      // Clock instances for internal periodic events.
      static Clock_Struct periodicClock;
      // Queue object used for app messages
      static Queue_Struct appMsg;
      static Queue_Handle appMsgQueue;
      Task_Struct sbpTask;
      Char sbpTaskStack[SBP_TASK_STACK_SIZE];
      // Scan response data (max size = 31 bytes)
      static uint8_t scanRspData[] =
        // complete name
        0x14,   // length of this data
        GAP_ADTYPE_LOCAL_NAME_COMPLETE,
        'S',
        'i',
        'm',
        'p',
        'l',
        'e',
        'B',
        'L',
        'E',
        'P',
        'e',
        'r',
        'i',
        'p',
        'h',
        'e',
        'r',
        'a',
        'l',
        // connection interval range
        0x05,   // length of this data
        GAP_ADTYPE_SLAVE_CONN_INTERVAL_RANGE,
        LO_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL),   // 100ms
        HI_UINT16(DEFAULT_DESIRED_MIN_CONN_INTERVAL),
        LO_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL),   // 1s
        HI_UINT16(DEFAULT_DESIRED_MAX_CONN_INTERVAL),
        // Tx power level
        0x02,   // length of this data
        GAP_ADTYPE_POWER_LEVEL,
        0       // 0dBm
      // Advertisement data (max size = 31 bytes, though this is
      // best kept short to conserve power while advertising)
      static uint8_t advertData[] =
        // Flags: this field sets the device to use general discoverable
        // mode (advertises indefinitely) instead of general
        // discoverable mode (advertise for 30 seconds at a time)
        GAP_ADTYPE_FLAGS,
        DEFAULT_DISCOVERABLE_MODE | GAP_ADTYPE_FLAGS_BREDR_NOT_SUPPORTED,
        // service UUID, to notify central devices what services are included
        // in this peripheral
        0x03,   // length of this data
        GAP_ADTYPE_16BIT_MORE,      // some of the UUID's, but not all
        LO_UINT16(SIMPLEPROFILE_SERV_UUID),
        HI_UINT16(SIMPLEPROFILE_SERV_UUID)
      // GAP GATT Attributes
       * LOCAL FUNCTIONS
      static void SimplePeripheral_init( void );
      static void SimplePeripheral_taskFxn(UArg a0, UArg a1);
      static uint8_t SimplePeripheral_processStackMsg(ICall_Hdr *pMsg);
      static uint8_t SimplePeripheral_processGATTMsg(gattMsgEvent_t *pMsg);
      static void SimplePeripheral_processAppMsg(sbpEvt_t *pMsg);
      static void SimplePeripheral_processStateChangeEvt(gaprole_States_t newState);
      static void SimplePeripheral_processCharValueChangeEvt(uint8_t paramID);
      static void SimplePeripheral_performPeriodicTask(void);
      static void SimplePeripheral_clockHandler(UArg arg);
      static void SimplePeripheral_passcodeCB(uint8_t *deviceAddr,
                                              uint16_t connHandle,
                                              uint8_t uiInputs, uint8_t uiOutputs,
                                              uint32_t numComparison);
      static void SimplePeripheral_pairStateCB(uint16_t connHandle, uint8_t state,
                                               uint8_t status);
      static void SimplePeripheral_processPairState(uint8_t state, uint8_t status);
      static void SimplePeripheral_processPasscode(uint8_t uiOutputs);
      static void SimplePeripheral_stateChangeCB(gaprole_States_t newState);
      static void SimplePeripheral_charValueChangeCB(uint8_t paramID);
      static uint8_t SimplePeripheral_enqueueMsg(uint8_t event, uint8_t state,
                                                    uint8_t *pData);
      static void SimplePeripheral_connEvtCB(Gap_ConnEventRpt_t *pReport);
      static void SimplePeripheral_processConnEvt(Gap_ConnEventRpt_t *pReport);
       * EXTERN FUNCTIONS
      extern void AssertHandler(uint8 assertCause, uint8 assertSubcause);
       * PROFILE CALLBACKS
      // Peripheral GAPRole Callbacks
      static gapRolesCBs_t SimplePeripheral_gapRoleCBs =
        SimplePeripheral_stateChangeCB     // GAPRole State Change Callbacks
      // GAP Bond Manager Callbacks
      // These are set to NULL since they are not needed. The application
      // is set up to only perform justworks pairing.
      static gapBondCBs_t simplePeripheral_BondMgrCBs =
        SimplePeripheral_passcodeCB,  // Passcode callback
        SimplePeripheral_pairStateCB  // Pairing / Bonding state Callback
      // Simple GATT Profile Callbacks
      static simpleProfileCBs_t SimplePeripheral_simpleProfileCBs =
        SimplePeripheral_charValueChangeCB // Simple GATT Characteristic value change callback
       * PUBLIC FUNCTIONS
       * The following typedef and global handle the registration to connection event
      typedef enum
         NOT_REGISTER       = 0,
         FOR_AOA_SCAN       = 1,
         FOR_ATT_RSP        = 2,
         FOR_AOA_SEND       = 4,
         FOR_TOF_SEND       = 8
      }connectionEventRegisterCause_u;
      // Handle the registration and un-registration for the connection event, since only one can be registered.
      uint32_t       connectionEventRegisterCauseBitMap = NOT_REGISTER; //see connectionEventRegisterCause_u
       * @fn      SimplePeripheral_RegistertToAllConnectionEvent()
       * @brief   register to receive connection events for all the connection
       * @param connectionEventRegisterCause represents the reason for registration
       * @return @ref SUCCESS
      bStatus_t SimplePeripheral_RegistertToAllConnectionEvent (connectionEventRegisterCause_u connectionEventRegisterCause)
        bStatus_t status = SUCCESS;
        // in case  there is no registration for the connection event, make the registration
        if (!CONNECTION_EVENT_IS_REGISTERED)
          status = GAP_RegisterConnEventCb(SimplePeripheral_connEvtCB, GAP_CB_REGISTER, LINKDB_CONNHANDLE_ALL);
        if(status == SUCCESS)
          //add the reason bit to the bitamap.
          CONNECTION_EVENT_REGISTER_BIT_SET(connectionEventRegisterCause);
        return(status);
       * @fn      SimplePeripheral_UnRegistertToAllConnectionEvent()
       * @brief   Unregister connection events
      bStatus_t SimplePeripheral_UnRegistertToAllConnectionEvent (connectionEventRegisterCause_u connectionEventRegisterCause)
        CONNECTION_EVENT_REGISTER_BIT_REMOVE(connectionEventRegisterCause);
        // in case  there is no more registration for the connection event than unregister
          GAP_RegisterConnEventCb(SimplePeripheral_connEvtCB, GAP_CB_UNREGISTER, LINKDB_CONNHANDLE_ALL);
        return(status);
       * @fn      SimplePeripheral_createTask
       * @brief   Task creation function for the Simple Peripheral.
       * @param   None.
       * @return  None.
      void SimplePeripheral_createTask(void)
        Task_Params taskParams;
        // Configure task
        Task_Params_init(&taskParams);
        taskParams.stack = sbpTaskStack;
        taskParams.stackSize = SBP_TASK_STACK_SIZE;
        taskParams.priority = SBP_TASK_PRIORITY;
        Task_construct(&sbpTask, SimplePeripheral_taskFxn, &taskParams, NULL);
       * @fn      SimplePeripheral_init
       * @brief   Called during initialization and contains application
       *          specific initialization (ie. hardware initialization/setup,
       *          table initialization, power up notification, etc), and
       *          profile initialization/setup.
       * @param   None.
       * @return  None.
      static void SimplePeripheral_init(void)
        // N0 STACK API CALLS CAN OCCUR BEFORE THIS CALL TO ICall_registerApp
        // Register the current thread as an ICall dispatcher application
        // so that the application can send and receive messages.
        ICall_registerApp(&selfEntity, &syncEvent);
      #ifdef USE_RCOSC
        RCOSC_enableCalibration();
      #endif // USE_RCOSC
        // configure RF Core SMI Data Link
        IOCPortConfigureSet(IOID_12, IOC_PORT_RFC_GPO0, IOC_STD_OUTPUT);
        IOCPortConfigureSet(IOID_11, IOC_PORT_RFC_GPI0, IOC_STD_INPUT);
        // configure RF Core SMI Command Link
        IOCPortConfigureSet(IOID_10, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_OUT, IOC_STD_OUTPUT);
        IOCPortConfigureSet(IOID_9, IOC_IOCFG0_PORT_ID_RFC_SMI_CL_IN, IOC_STD_INPUT);
        // configure RF Core tracer IO
        IOCPortConfigureSet(IOID_8, IOC_PORT_RFC_TRC, IOC_STD_OUTPUT);
      #else // !USE_FPGA
        #if defined( DEBUG_SW_TRACE )
          IOCPortConfigureSet(IOID_8, IOC_PORT_RFC_TRC, IOC_STD_OUTPUT | IOC_CURRENT_4MA | IOC_SLEW_ENABLE);
        #endif // DEBUG_SW_TRACE
      #endif // USE_FPGA
        // Create an RTOS queue for message from profile to be sent to app.
        appMsgQueue = Util_constructQueue(&appMsg);
        // Create one-shot clocks for internal periodic events.
        Util_constructClock(&periodicClock, SimplePeripheral_clockHandler,
                            SBP_PERIODIC_EVT_PERIOD, 0, false, SBP_PERIODIC_EVT);
        //dispHandle = Display_open(SBP_DISPLAY_TYPE, NULL);
        // Set GAP Parameters: After a connection was established, delay in seconds
        // before sending when GAPRole_SetParameter(GAPROLE_PARAM_UPDATE_ENABLE,...)
        // uses GAPROLE_LINK_PARAM_UPDATE_INITIATE_BOTH_PARAMS or
        // GAPROLE_LINK_PARAM_UPDATE_INITIATE_APP_PARAMS
        // For current defaults, this has no effect.
        GAP_SetParamValue(TGAP_CONN_PAUSE_PERIPHERAL, DEFAULT_CONN_PAUSE_PERIPHERAL);
        // Setup the Peripheral GAPRole Profile. For more information see the User's
        // Guide:
        // http://software-dl.ti.com/lprf/sdg-latest/html/
          // By setting this to zero, the device will go into the waiting state after
          // being discoverable for 30.72 second, and will not being advertising again
          // until re-enabled by the application
          uint16_t advertOffTime = 0;
          uint8_t enableUpdateRequest = DEFAULT_ENABLE_UPDATE_REQUEST;
          uint16_t desiredMinInterval = DEFAULT_DESIRED_MIN_CONN_INTERVAL;
          uint16_t desiredMaxInterval = DEFAULT_DESIRED_MAX_CONN_INTERVAL;
          uint16_t desiredSlaveLatency = DEFAULT_DESIRED_SLAVE_LATENCY;
          uint16_t desiredConnTimeout = DEFAULT_DESIRED_CONN_TIMEOUT;
          GAPRole_SetParameter(GAPROLE_ADVERT_OFF_TIME, sizeof(uint16_t),
                               &advertOffTime);
          GAPRole_SetParameter(GAPROLE_SCAN_RSP_DATA, sizeof(scanRspData),
                               scanRspData);
          GAPRole_SetParameter(GAPROLE_ADVERT_DATA, sizeof(advertData), advertData);
          GAPRole_SetParameter(GAPROLE_PARAM_UPDATE_ENABLE, sizeof(uint8_t),
                               &enableUpdateRequest);
          GAPRole_SetParameter(GAPROLE_MIN_CONN_INTERVAL, sizeof(uint16_t),
                               &desiredMinInterval);
          GAPRole_SetParameter(GAPROLE_MAX_CONN_INTERVAL, sizeof(uint16_t),
                               &desiredMaxInterval);
          GAPRole_SetParameter(GAPROLE_SLAVE_LATENCY, sizeof(uint16_t),
                               &desiredSlaveLatency);
          GAPRole_SetParameter(GAPROLE_TIMEOUT_MULTIPLIER, sizeof(uint16_t),
                               &desiredConnTimeout);
        // Set the Device Name characteristic in the GAP GATT Service
        // For more information, see the section in the User's Guide:
       // GGS_SetParameter(GGS_DEVICE_NAME_ATT, GAP_DEVICE_NAME_LEN, attDeviceName);
        // Set GAP Parameters to set the advertising interval
        // For more information, see the GAP section of the User's Guide:
          // Use the same interval for general and limited advertising.
          // Note that only general advertising will occur based on the above configuration
          uint16_t advInt = DEFAULT_ADVERTISING_INTERVAL;
          GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MIN, advInt);
          GAP_SetParamValue(TGAP_LIM_DISC_ADV_INT_MAX, advInt);
          GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MIN, advInt);
          GAP_SetParamValue(TGAP_GEN_DISC_ADV_INT_MAX, advInt);
        // Setup the GAP Bond Manager. For more information see the section in the
        // User's Guide:
          // Don't send a pairing request after connecting; the peer device must
          // initiate pairing
          uint8_t pairMode = GAPBOND_PAIRING_MODE_WAIT_FOR_REQ;
          // Use authenticated pairing: require passcode.
          uint8_t mitm = TRUE;
          // This device only has display capabilities. Therefore, it will display the
          // passcode during pairing. However, since the default passcode is being
          // used, there is no need to display anything.
          uint8_t ioCap = GAPBOND_IO_CAP_DISPLAY_ONLY;
          // Request bonding (storing long-term keys for re-encryption upon subsequent
          // connections without repairing)
          uint8_t bonding = TRUE;
          // Whether to replace the least recently used entry when bond list is full,
          // and a new device is bonded.
          // Alternative is pairing succeeds but bonding fails, unless application has
          // manually erased at least one bond.
          uint8_t replaceBonds = FALSE;
          GAPBondMgr_SetParameter(GAPBOND_PAIRING_MODE, sizeof(uint8_t), &pairMode);
          GAPBondMgr_SetParameter(GAPBOND_MITM_PROTECTION, sizeof(uint8_t), &mitm);
          GAPBondMgr_SetParameter(GAPBOND_IO_CAPABILITIES, sizeof(uint8_t), &ioCap);
          GAPBondMgr_SetParameter(GAPBOND_BONDING_ENABLED, sizeof(uint8_t), &bonding);
          GAPBondMgr_SetParameter(GAPBOND_LRU_BOND_REPLACEMENT, sizeof(uint8_t), &replaceBonds);
        // Initialize GATT attributes
        GGS_AddService(GATT_ALL_SERVICES);           // GAP GATT Service
        GATTServApp_AddService(GATT_ALL_SERVICES);   // GATT Service
        DevInfo_AddService();                        // Device Information Service
        SimpleProfile_AddService(GATT_ALL_SERVICES); // Simple GATT Profile
        // Setup the SimpleProfile Characteristic Values
        // For more information, see the sections in the User's Guide:
          uint8_t charValue1 = 1;
          uint8_t charValue2 = 2;
          uint8_t charValue3 = 3;
          uint8_t charValue4 = 4;
      //    uint8_t charValue5[SIMPLEPROFILE_CHAR5_LEN] = { 1, 2, 3, 4, 5 };
      //    SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR1, sizeof(uint8_t),     &charValue1);
          //SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR2, sizeof(uint8_t),   &charValue2);
          //SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR3, sizeof(uint8_t), &charValue3);
          //SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR4, sizeof(uint8_t),  &charValue4);
          //SimpleProfile_SetParameter(SIMPLEPROFILE_CHAR5, SIMPLEPROFILE_CHAR5_LEN,  charValue5);
        // Start the Device:
        // Please Notice that in case of wanting to use the GAPRole_SetParameter
        // function with GAPROLE_IRK or GAPROLE_SRK parameter - Perform
        // these function calls before the GAPRole_StartDevice use.
        // (because Both cases are updating the gapRole_IRK & gapRole_SRK variables).
        VOID GAPRole_StartDevice(&SimplePeripheral_gapRoleCBs);
        // Register callback with SimpleGATTprofile
        SimpleProfile_RegisterAppCBs(&SimplePeripheral_simpleProfileCBs);
        // Start Bond Manager and register callback
        VOID GAPBondMgr_Register(&simplePeripheral_BondMgrCBs);
        // Register with GAP for HCI/Host messages. This is needed to receive HCI
        // events. For more information, see the section in the User's Guide:
        GAP_RegisterForMsgs(selfEntity);
        // Register for GATT local events and ATT Responses pending for transmission
        GATT_RegisterForMsgs(selfEntity);
        //Set default values for Data Length Extension
          //Set initial values to maximum, RX is set to max. by default(251 octets, 2120us)
          #define APP_SUGGESTED_PDU_SIZE 251 //default is 27 octets(TX)
          #define APP_SUGGESTED_TX_TIME 2120 //default is 328us(TX)
          //This API is documented in hci.h
          //See the LE Data Length Extension section in the BLE-Stack User's Guide for information on using this command:
          //http://software-dl.ti.com/lprf/sdg-latest/html/cc2640/index.html
          //HCI_LE_WriteSuggestedDefaultDataLenCmd(APP_SUGGESTED_PDU_SIZE, APP_SUGGESTED_TX_TIME);
        PIN_open(&sbpLedState, sbpLedPins);
          PIN_setOutputValue(&sbpLedState, Board_CTRL_T, Board_SWITCH_OFF);//���������� ����� ���������� 1912
          PIN_setOutputValue(&sbpLedState, Board_SPI_ACC_EN, Board_SWITCH_OFF);//  /*SPI*/
        //IRLM
        #ifdef IRLM
          PIN_setOutputValue(&sbpLedState, Board_ADC_T_EN, Board_SWITCH_OFF);//������ ������� � ��������������
        #else
          PIN_setOutputValue(&sbpLedState, Board_ADC_T_EN, Board_SWITCH_ON);//������ ������� � �������������� ��� IRLM
        #endif
          PIN_open(&AccelCS_PinState, AccelCS_PinInitTable);
          PIN_setOutputValue(&AccelCS_PinState, Board_SPI_ACCEL_CS, Board_SPI_ACCEL_CS_ON);
          GPTimerCC26XX_Params timerParams;
          GPTimerCC26XX_Params_init(&timerParams);
          timerParams.width = GPT_CONFIG_16BIT;
          timerParams.mode  = GPT_MODE_EDGE_COUNT;
          timerParams.direction = GPTimerCC26XX_DIRECTION_UP;
          timerParams.debugStallMode = GPTimerCC26XX_DEBUG_STALL_OFF;
          cTimer = GPTimerCC26XX_open(Board_GPTIMER1A, &timerParams);
          if(cTimer == NULL) {
                //Log_error0("Failed to open GPTimer");
          GPTimerCC26XX_registerInterrupt(cTimer, ctimerCallback, GPT_INT_CAPTURE_MATCH);//���������� �� ��������� ��������� ����� ���������
          GPTimerCC26XX_setLoadValue(cTimer, 0xFFFF);
          GPTimerCC26XX_setMatchValue(cTimer, 5000);
          timerPinHandle = PIN_open(&timerPinState, GptPinInitTable);
          GPTimerCC26XX_PinMux pinMux = GPTimerCC26XX_getPinMux(cTimer);
          PINCC26XX_setMux(timerPinHandle, PIN_ID(Board_COUNTER), pinMux);
      #if !defined (USE_LL_CONN_PARAM_UPDATE)
        // Get the currently set local supported LE features
        // The HCI will generate an HCI event that will get received in the main
        // loop
        HCI_LE_ReadLocalSupportedFeaturesCmd();
      #endif // !defined (USE_LL_CONN_PARAM_UPDATE)
       // Display_print0(dispHandle, 0, 0, "BLE Peripheral");
       * @fn      SimplePeripheral_taskFxn
       * @brief   Application task entry point for the Simple Peripheral.
       * @param   a0, a1 - not used.
       * @return  None.
        // Initialize application
        SimplePeripheral_init();
        // Application main loop
        for (;;)
          uint32_t events;
          // Waits for an event to be posted associated with the calling thread.
          // Note that an event associated with a thread is posted when a
          // message is queued to the message receive queue of the thread
          events = Event_pend(syncEvent, Event_Id_NONE, SBP_ALL_EVENTS,
                              ICALL_TIMEOUT_FOREVER);
          if (events)
            ICall_EntityID dest;
            ICall_ServiceEnum src;
            ICall_HciExtEvt *pMsg = NULL;
            // Fetch any available messages that might have been sent from the stack
            if (ICall_fetchServiceMsg(&src, &dest,
                                      (void **)&pMsg) == ICALL_ERRNO_SUCCESS)
              uint8 safeToDealloc = TRUE;
              if ((src == ICALL_SERVICE_CLASS_BLE) && (dest == selfEntity))
                ICall_Stack_Event *pEvt = (ICall_Stack_Event *)pMsg;
                if (pEvt->signature != 0xffff)
                  // Process inter-task message
                  safeToDealloc = SimplePeripheral_processStackMsg((ICall_Hdr *)pMsg);
              if (pMsg && safeToDealloc)
                ICall_freeMsg(pMsg);
            // If RTOS queue is not empty, process app message.
            if (events & SBP_QUEUE_EVT)
              while (!Queue_empty(appMsgQueue))
                sbpEvt_t *pMsg = (sbpEvt_t *)Util_dequeueMsg(appMsgQueue);
                if (pMsg)
                  // Process message.
                  SimplePeripheral_processAppMsg(pMsg);
                  // Free the space from the message.
                  ICall_free(pMsg);
            if (events & SBP_PERIODIC_EVT)
              Util_startClock(&periodicClock);
              // Perform periodic application task
              SimplePeripheral_performPeriodicTask();
       * @fn      SimplePeripheral_processStackMsg
       * @brief   Process an incoming stack message.
       * @param   pMsg - message to process
       * @return  TRUE if safe to deallocate incoming message, FALSE otherwise.
        uint8_t safeToDealloc = TRUE;
        switch (pMsg->event)
          case GATT_MSG_EVENT:
            // Process GATT message
            safeToDealloc = SimplePeripheral_processGATTMsg((gattMsgEvent_t *)pMsg);
            break;
          case HCI_GAP_EVENT_EVENT:
              // Process HCI message
              switch(pMsg->status)
                case HCI_COMMAND_COMPLETE_EVENT_CODE:
                  // Process HCI Command Complete Event
                    // This code will disable the use of the LL_CONNECTION_PARAM_REQ
                    // control procedure (for connection parameter updates, the
                    // L2CAP Connection Parameter Update procedure will be used
                    // instead). To re-enable the LL_CONNECTION_PARAM_REQ control
                    // procedures, define the symbol USE_LL_CONN_PARAM_UPDATE
                    // The L2CAP Connection Parameter Update procedure is used to
                    // support a delta between the minimum and maximum connection
                    // intervals required by some iOS devices.
                    // Parse Command Complete Event for opcode and status
                    hciEvt_CmdComplete_t* command_complete = (hciEvt_CmdComplete_t*) pMsg;
                    uint8_t   pktStatus = command_complete->pReturnParam[0];
                    //find which command this command complete is for
                    switch (command_complete->cmdOpcode)
                      case HCI_LE_READ_LOCAL_SUPPORTED_FEATURES:
                          if (pktStatus == SUCCESS)
                            uint8_t featSet[8];
                            // Get current feature set from received event (bits 1-9
                            // of the returned data
                            memcpy( featSet, &command_complete->pReturnParam[1], 8 );
                            // Clear bit 1 of byte 0 of feature set to disable LL
                            // Connection Parameter Updates
                            CLR_FEATURE_FLAG( featSet[0], LL_FEATURE_CONN_PARAMS_REQ );
                            // Update controller with modified features
                            HCI_EXT_SetLocalSupportedFeaturesCmd( featSet );
                        break;
                      default:
                        //do nothing
                        break;
                  break;
                case HCI_BLE_HARDWARE_ERROR_EVENT_CODE:
                  AssertHandler(HAL_ASSERT_CAUSE_HARDWARE_ERROR,0);
                  break;
                default:
                  break;
            break;
            default:
              // do nothing
              break;
        return (safeToDealloc);
       * @fn      SimplePeripheral_processGATTMsg
       * @brief   Process GATT messages and events.
        // See if GATT server was unable to transmit an ATT response
        // Free message payload. Needed only for ATT Protocol messages
        GATT_bm_free(&pMsg->msg, pMsg->method);
        // It's safe to free the incoming message
        return (TRUE);
       * @fn      SimplePeripheral_processConnEvt
       * @brief   Process connection event.
       * @param pReport pointer to connection event report
        if( CONNECTION_EVENT_REGISTRATION_CAUSE(FOR_ATT_RSP))
          // The GATT server might have returned a blePending as it was trying
          // to process an ATT Response. Now that we finished with this
          // connection event, let's try sending any remaining ATT Responses
          // on the next connection event.
          // Try to retransmit pending ATT Response (if any)
       * @fn      SimplePeripheral_processAppMsg
       * @brief   Process an incoming callback from a profile.
       * @return  None.
        switch (pMsg->hdr.event)
          case SBP_STATE_CHANGE_EVT:
              SimplePeripheral_processStateChangeEvt((gaprole_States_t)pMsg->
                                                      hdr.state);
            break;
          case SBP_CHAR_CHANGE_EVT:
              SimplePeripheral_processCharValueChangeEvt(pMsg->hdr.state);
            break;
          // Pairing event
          case SBP_PAIRING_STATE_EVT:
              SimplePeripheral_processPairState(pMsg->hdr.state, *pMsg->pData);
              ICall_free(pMsg->pData);
              break;
          // Passcode event
          case SBP_PASSCODE_NEEDED_EVT:
              SimplePeripheral_processPasscode(*pMsg->pData);
              break;
          case SBP_CONN_EVT:
              SimplePeripheral_processConnEvt((Gap_ConnEventRpt_t *)(pMsg->pData));
              break;
          default:
            // Do nothing.
            break;
       * @fn      SimplePeripheral_stateChangeCB
       * @brief   Callback from GAP Role indicating a role state change.
       * @param   newState - new state
       * @return  None.
        SimplePeripheral_enqueueMsg(SBP_STATE_CHANGE_EVT, newState, NULL);
       * @fn      SimplePeripheral_processStateChangeEvt
       * @brief   Process a pending GAP Role state change event.
       * @return  None.
      #ifdef PLUS_BROADCASTER
        static bool firstConnFlag = false;
      #endif // PLUS_BROADCASTER
        switch ( newState )
          case GAPROLE_STARTED:
              uint8_t ownAddress[B_ADDR_LEN];
              uint8_t systemId[DEVINFO_SYSTEM_ID_LEN];
              GAPRole_GetParameter(GAPROLE_BD_ADDR, ownAddress);
              // use 6 bytes of device address for 8 bytes of system ID value
              systemId[0] = ownAddress[0];
              systemId[1] = ownAddress[1];
              systemId[2] = ownAddress[2];
              // set middle bytes to zero
              systemId[4] = 0x00;
              systemId[3] = 0x00;
              // shift three bytes up
              systemId[7] = ownAddress[5];
              systemId[6] = ownAddress[4];
              systemId[5] = ownAddress[3];
              DevInfo_SetParameter(DEVINFO_SYSTEM_ID, DEVINFO_SYSTEM_ID_LEN, systemId);
              // Display device address
              //Display_print0(dispHandle, 1, 0, Util_convertBdAddr2Str(ownAddress));
              //Display_print0(dispHandle, 2, 0, "Initialized");
              // Device starts advertising upon initialization of GAP
              uint8_t initialAdvertEnable = TRUE;
              // Set the Peripheral GAPRole Parameters
              GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t),
                               &initialAdvertEnable);
            break;
          case GAPROLE_ADVERTISING:
            //Display_print0(dispHandle, 2, 0, "Advertising");
            break;
          // After a connection is dropped, a device in PLUS_BROADCASTER will continue
          // sending non-connectable advertisements and shall send this change of
          // state to the application.  These are then disabled here so that sending
          // connectable advertisements can resume.
          case GAPROLE_ADVERTISING_NONCONN:
              uint8_t advertEnabled = FALSE;
              // Disable non-connectable advertising.
              GAPRole_SetParameter(GAPROLE_ADV_NONCONN_ENABLED, sizeof(uint8_t),
                                 &advertEnabled);
              advertEnabled = TRUE;
              // Enabled connectable advertising.
                                   &advertEnabled);
              // Reset flag for next connection.
              attRsp_freeAttRsp(bleNotConnected);
            break;
      #endif //PLUS_BROADCASTER
          case GAPROLE_CONNECTED:
              linkDBInfo_t linkInfo;
              uint8_t numActive = 0;
              numActive = linkDB_NumActive();
              // Use numActive to determine the connection handle of the last
              // connection
              if ( linkDB_GetInfo( numActive - 1, &linkInfo ) == SUCCESS )
                //Display_print1(dispHandle, 2, 0, "Num Conns: %d", (uint16_t)numActive);
                //Display_print0(dispHandle, 3, 0, Util_convertBdAddr2Str(linkInfo.addr));
              else
                uint8_t peerAddress[B_ADDR_LEN];
                GAPRole_GetParameter(GAPROLE_CONN_BD_ADDR, peerAddress);
                //Display_print0(dispHandle, 2, 0, "Connected");
                //Display_print0(dispHandle, 3, 0, Util_convertBdAddr2Str(peerAddress));
                // Only turn advertising on for this state when we first connect
                // otherwise, when we go from connected_advertising back to this state
                // we will be turning advertising back on.
                if (firstConnFlag == false)
                  uint8_t advertEnabled = FALSE; // Turn on Advertising
                  // Disable connectable advertising.
                                       &advertEnabled);
                  // Set to true for non-connectable advertising.
                  // Enable non-connectable advertising.
                                       &advertEnabled);
                  firstConnFlag = true;
            break;
          case GAPROLE_CONNECTED_ADV:
           // Display_print0(dispHandle, 2, 0, "Connected Advertising");
            break;
          case GAPROLE_WAITING:
              uint8_t advertReEnable = TRUE;
              Util_stopClock(&periodicClock);
              //attRsp_freeAttRsp(bleNotConnected);
              // Clear remaining lines
             // Display_clearLines(dispHandle, 3, 5);
              GAPRole_SetParameter(GAPROLE_ADVERT_ENABLED, sizeof(uint8_t), &advertReEnable);
            break;
          case GAPROLE_WAITING_AFTER_TIMEOUT:
            //Display_print0(dispHandle, 2, 0, "Timed Out");
            //Display_clearLines(dispHandle, 3, 5);
            break;
          case GAPROLE_ERROR:
            //Display_print0(dispHandle, 2, 0, "Error");
            break;
          default:
            //Display_clearLine(dispHandle, 2);
            break;
       * @fn      SimplePeripheral_charValueChangeCB
       * @brief   Callback from Simple Profile indicating a characteristic
       *          value change.
       * @param   paramID - parameter ID of the value that was changed.
       * @return  None.
        SimplePeripheral_enqueueMsg(SBP_CHAR_CHANGE_EVT, paramID, 0);
       * @fn      SimplePeripheral_processCharValueChangeEvt
       * @brief   Process a pending Simple Profile characteristic value change
       *          event.
       * @return  None.
        uint8_t newValue;
        switch(paramID)
          default:
            // should not reach here!
            break;
       * @fn      SimplePeripheral_performPeriodicTask
       * @brief   Perform a periodic application task. This function gets called
       *          every five seconds (SBP_PERIODIC_EVT_PERIOD). In this example,
       *          the value of the third characteristic in the SimpleGATTProfile
       *          service is retrieved from the profile, and then copied into the
       *          value of the the fourth characteristic.
       * @param   None.
       * @return  None.
        uint8_t valueToCopy;
       * @fn      SimplePeripheral_pairStateCB
       * @brief   Pairing state callback.
       * @return  none
                                                  uint8_t status)
        uint8_t *pData;
        // Allocate space for the event data.
        if ((pData = ICall_malloc(sizeof(uint8_t))))
          *pData = status;
          // Queue the event.
          SimplePeripheral_enqueueMsg(SBP_PAIRING_STATE_EVT, state, pData);
       * @fn      SimplePeripheral_processPairState
       * @brief   Process the new paring state.
       * @return  none
        if (state == GAPBOND_PAIRING_STATE_STARTED)
         // Display_print0(dispHandle, 2, 0, "Pairing started");
        else if (state == GAPBOND_PAIRING_STATE_COMPLETE)
          if (status == SUCCESS)
           // Display_print0(dispHandle, 2, 0, "Pairing success");
          else
            //Display_print1(dispHandle, 2, 0, "Pairing fail: %d", status);
        else if (state == GAPBOND_PAIRING_STATE_BONDED)
            //Display_print0(dispHandle, 2, 0, "Bonding success");
        else if (state == GAPBOND_PAIRING_STATE_BOND_SAVED)
            //Display_print0(dispHandle, 2, 0, "Bond save success");
          else
            //Display_print1(dispHandle, 2, 0, "Bond save failed: %d", status);
       * @fn      SimplePeripheral_passcodeCB
       * @brief   Passcode callback.
       * @return  none
                                              uint8_t uiInputs,
                                              uint8_t uiOutputs,
        uint8_t *pData;
        // Allocate space for the passcode event.
          *pData = uiOutputs;
          // Enqueue the event.
          SimplePeripheral_enqueueMsg(SBP_PASSCODE_NEEDED_EVT, 0, pData);
       * @fn      SimplePeripheral_processPasscode
       * @brief   Process the Passcode request.
       * @return  none
        // This app uses a default passcode. A real-life scenario would handle all
        // pairing scenarios and likely generate this randomly.
        uint32_t passcode = B_APP_DEFAULT_PASSCODE;
        // Display passcode to user
        if (uiOutputs != 0)
         // Display_print1(dispHandle, 4, 0, "Passcode: %d", passcode);
        uint16_t connectionHandle;
        GAPRole_GetParameter(GAPROLE_CONNHANDLE, &connectionHandle);
        // Send passcode response
        GAPBondMgr_PasscodeRsp(connectionHandle, SUCCESS, passcode);
       * @fn      SimplePeripheral_clockHandler
       * @brief   Handler function for clock timeouts.
       * @param   arg - event type
       * @return  None.
        // Wake up the application.
        Event_post(syncEvent, arg);
       * @fn      SimplePeripheral_connEvtCB
       * @brief   Connection event callback.
        // Enqueue the event for processing in the app context.
        if( SimplePeripheral_enqueueMsg(SBP_CONN_EVT, 0 ,(uint8_t *) pReport) == FALSE)
          ICall_free(pReport);
       * @brief   Creates a message and puts the message in RTOS queue.
       * @param   event - message event.
       * @param   state - message state.
       * @param   pData - message data pointer.
       * @return  TRUE or FALSE
                                                 uint8_t *pData)
        sbpEvt_t *pMsg = ICall_malloc(sizeof(sbpEvt_t));
        // Create dynamic pointer to message.
        if (pMsg)
          pMsg->hdr.event = event;
          pMsg->hdr.state = state;
          pMsg->pData = pData;
          // Enqueue the message.
          return Util_enqueueMsg(appMsgQueue, syncEvent, (uint8_t *)pMsg);
        return FALSE;
  • Thank you . means a large current with gpt is this normal? Or can the current be reduced?
    this is important to me, I want to get the minimum current for longer battery operation of the device
  • Please refer to TI Drivers Power Management and use ti.sysbios.knl.Clock instead of GPTimer.  This will allow for standby entry and will service the clock function once the timeout expires.
    Ryan
  • Thank you.
    1. I tried different modes in Power_setDependency(). But the current consumption has not decreased.
    2. I use GPTimer in pulse counter mode. Tell me how to do without GPTimer, but I need a pulse counter?
  • 1. Standby mode will be blocked since there is a hardware dependency (GPTimer) which requires active mode
    2. You can use GPIO interrupts to count pulses manually, or close the GPTimer when not counting pulses to allow entry into standby and thus lower power
    Ryan
  • Thank you.
    1. Regarding GPIO, I have pulses with a frequency of 300 kHz. I think that its use will affect the reliability of the execution of the main program code. I'm using TI-RTOS
    2. GPTimer - I do not use it all the time, but I turn it on for 100 ms and at this time the current rises to 4 mA
    3. I use BLE. How to reduce core current consumption during GPTimer operation?
  • Given the high frequency of pulses to count, you will need to develop your application to negotiate a compromise between low power consumption and measuring pulses with GPTimer enabled.  You appear to already be familiar with enabling low power modes for simple_peripheral.c and you can consult the SWRU393_CC2640_BLE_Software_Developer's_Guide.pdf document from the BLE SDK.  Other options include using the Sensor Controller Pulse Counter on considering an external IC which can count pulses.
    Ryan
  • What other options are there for counting pulses? Thank you
  • You could ask the Logic Forum for a parts recommendation.
    Ryan
  • Hi Alex,
    If you are using CC2640R2F, according to this you can use the sensor controller to count pulses.
    https://software-dl.ti.com/lprf/sensor_controller_studio/docs/cc13x0_cc26x0_help/html/pulse_counter__0.html
    -kel
  • Hi
    i using cc2640r2l Disappointed
