CC2652P: There are some issues of Router's non-silent-rejoin in SDK6.30 & SDK6.40
Part Number: CC2652P
1,When a router act non--silent-rejoin, the rejoin-timeout is 0(NWK_REJOIN_TIMEOUT_EVT), that will a failed-rejoin in "ZDO_JoinConfirmCB".
 It can be fixed like this
fix ZDApp_RestoreNetworkState, set a valid timeout for router's rejoining.
uint8_t ZDApp_RestoreNetworkState( void )
      else if( ZG_DEVICE_RTRONLY_TYPE &&
               (zgRouterSilentRejoin == FALSE) )
        devStartMode = MODE_REJOIN;
        _NIB.nwkState = NWK_INIT;
        // set rejoin-timeout to be valid, fixed by luoyiming 2023-05-13
        if(nwk_pollRateTable.PollRateRejoin == 0)
          nwk_pollRateTable.PollRateRejoin = REJOIN_POLL_RATE;
fix ZDO_JoinConfirmCB, stop NWK_REJOIN_TIMEOUT_EVT timer for router.
void ZDO_JoinConfirmCB( uint16_t PanId, ZStatus_t Status )
  (void)PanId;  // remove if this parameter is used.
  nwkStatus = (byte)Status;
  if ( Status == ZSUCCESS )
    if ( ZSTACK_END_DEVICE_BUILD
      || (ZSTACK_ROUTER_BUILD && BUILD_FLEXABLE && ((_NIB.CapabilityFlags & ZMAC_ASSOC_CAPINFO_FFD_TYPE) == 0)))
      neighborEntry_t *pItem;
      // We don't need the neighbor table entries.
      // Clear the neighbor Table to remove beacon information
      nwkNeighborInitTable();
      // Force a neighbor table entry for the parent
      pItem = nwkNeighborFindEmptySlot();
      if ( pItem != NULL )
        memset( pItem, 0x00, sizeof ( neighborEntry_t  )  );
        pItem->neighborAddress = _NIB.nwkCoordAddress;
        osal_cpyExtAddr( pItem ->neighborExtAddr, _NIB. nwkCoordExtAddress );
        pItem->panId = _NIB. nwkPanId;
        pItem->linkInfo.rxLqi = DEF_LQI;
        pItem->linkInfo.txCounter = DEF_LINK_COUNTER;
        pItem->linkInfo.txCost = DEF_LINK_COST;
    // Stop NWK auto poll for Router, fixed by luoyiming 2023-05-13
    if( ZG_DEVICE_RTRONLY_TYPE )
      OsalPortTimers_stopTimer(NWK_TaskID, NWK_AUTO_POLL_EVT);
    if ( devState == DEV_HOLD )
      ZDApp_ChangeState( DEV_NWK_JOINING );
  // Pass the join confirm to higher layer if callback registered
  if (zdoCBFunc[ZDO_JOIN_CNF_CBID] != NULL )
    zdoJoinCnf_t joinCnf;
    joinCnf.status = Status;
    joinCnf.deviceAddr = _NIB.nwkDevAddress;
    joinCnf.parentAddr = _NIB.nwkCoordAddress;
    zdoCBFunc[ZDO_JOIN_CNF_CBID]( (void*)&joinCnf );
  // Notify ZDApp
  ZDApp_SendMsg( ZDAppTaskID, ZDO_NWK_JOIN_IND, sizeof(OsalPort_EventHdr), (byte*)NULL );
2, If Router act unsecured-rejoin, it will request APS-link key again, it can be fixed like this
  if ( events & ZDO_DEVICE_AUTH )
    ZDApp_StoreNwkSecMaterial();
    ZDApp_DeviceAuthEvt();
    // Don't exchange key for unsecured-rejoin, fixed by luoyiming 2023-05-13
    if(!bdb_isDeviceNonFactoryNew())
      bdb_setNodeIsOnANetwork(TRUE);
      bdb_reportCommissioningState(BDB_COMMISSIONING_STATE_JOINING, TRUE);
    // Return unprocessed events
    return (events ^ ZDO_DEVICE_AUTH);
3, When Router act non-silent-rejoin, if Router can't discover any parent of its network,it will leave the current network. It can be fixed like this
    case ZDO_NWK_DISC_CNF:
      if (devState != DEV_NWK_DISC)
        break;
      if ( ZG_BUILD_JOINING_TYPE && ZG_DEVICE_JOINING_TYPE )
        //Rejoin or resume
        if(bdb_isDeviceNonFactoryNew())
          if(bdb_rejoinNwk() == ZSuccess)
            return;
          else
            if(ZG_DEVICE_ENDDEVICE_TYPE)
              bdb_parentLost();
            //Router change to orphan state when discover failed, fixed by luoyiming 2023-05-13
            else if(ZG_DEVICE_RTRONLY_TYPE)
              ZDApp_ChangeState( DEV_NWK_ORPHAN );
          return;
        if(nwk_getNwkDescList())
          bdb_nwkDiscoveryAttempt(TRUE);
        else
          bdb_nwkDiscoveryAttempt(FALSE);
    break;
void ZDApp_ProcessNetworkJoin( void )
  if ( (devState == DEV_NWK_JOINING) ||
      ((devState == DEV_NWK_ORPHAN)  &&
       (ZDO_Config_Node_Descriptor.LogicalType == NODETYPE_ROUTER)) )
  else if ( devState == DEV_NWK_ORPHAN ||
            devState == DEV_NWK_SEC_REJOIN_CURR_CHANNEL ||
            devState == DEV_NWK_TC_REJOIN_CURR_CHANNEL ||
            devState == DEV_NWK_TC_REJOIN_ALL_CHANNEL ||
            devState == DEV_NWK_SEC_REJOIN_ALL_CHANNEL )
    // results of an orphaning attempt by this device
    if (nwkStatus == ZSuccess)
    else
      //Router change to orphan state when rejoin failed, fixed by luoyiming 2023-05-13
  else if ( devState != DEV_HOLD )
  • Hi Aries,
    1. Thank you for reporting this, I recognize that it is a bug and have submitted a ticket to the Software Development Team.
    2. The current application assumes that a Trust Center (TC)/unsecure rejoin is taking place because the NWK key is unavailable or incorrect, thus requesting a new APS link key.
    3. The existing operation will restart the joining process if the router cannot find the original network to rejoin, similar to plausible ZED lost network behavior.
    2 and 3 are custom application decisions.
    Regards.
  • Router's rejoin should be same with End-Device's. Router must remember Trust-Center's Ext-PANID and APS-Key when join in a network. When Trust-Center's NWK-Key, PANID, logic-channel have been changed, Router should take place Secured-rejoin or unsecured-rejoin to find the new NWK-key, new PANID and new logic-channel of Trust-Center's.
