Part Number: TI-API
What do the v2 quote API error codes mean?
| Code | Type | Reason | Message |
| TI-TXT-045 | ERROR | Duplicate Quote request | customerQuoteNumber is a duplicate of an existing quote. Enter a unique customerQuoteNumber and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-047 | ERROR | Invalid endCustomerCompanyName | endCustomerCompanyName exceeds the maximum length of 35 characters. Enter a valid endCustomerCompanyName that does not exceed 35 characters and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-070 | ERROR | Missing tiPartNumber | tiPartNumber cannot be null or empty. Enter a valid tiPartNumber and resubmit the request. |
| TI-TXT-011 | ERROR | Missing endCustomerCompanyName | endCustomerCompanyName cannot be null or empty. Enter a valid endCustomerCompanyName and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-071 | ERROR | endCustomerCompanyName not in the same sales area or blocked | endCustomerCompanyName setup issue. For assistance, contact TI Customer support center https://support.ti.com/csm |
| TI-TXT-065 | ERROR | Invalid competitorName | competitorName is not valid. Verify the competitorName and resubmit the request. |
| TI-TXT-030 | ERROR | Invalid endCustomerCompanyName | endCustomerCompanyName is not valid. Verify the endCustomerCompanyName and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-036 | ERROR | Invalid tiPartNumber | tiPartNumber is not valid. Verify the tiPartNumber with product information API and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-063 | ERROR | Invalid quoteReason | quoteReason is not valid. Enter a valid 2-character for quoteReason and resubmit request. See e2e.ti.com/.../1213304 for more details |
| TI-TXT-066 | ERROR | Invalid requestedUnitPriceCurrencyCode | requestedUnitPriceCurrencyCode is not valid. Enter a valid requestedUnitPriceCurrencyCode and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-064 | ERROR | Invalid User ID. | message: User ID does not exist. For assistance, contact TI Customer support center https://support.ti.com/csm. |
| TI-TXT-075 | ERROR | Invalid competitorUnitPrice | competitorUnitPrice has an invalid value. Enter a valid competitorUnitPrice and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-077 | ERROR | Invalid requestedUnitPrice | message: requestedUnitPrice has an invalid value. Enter a valid requestedUnitPrice and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-SYS | ERROR | Invalid quantity. | Invalid quantity for item {tiPartNumber}. It must be {quantity]. Correct quantity and resubmit. Refer to documentation regarding MOQ, MIV, SPQ. |
| TI-TXT-020 | ERROR | Unable to order tiPartNumber | tiPartNumber {tiPartNumber} is no longer available to order. Remove {tiPartNumber} and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-042 | ERROR | tiPartNumber has been excluded | tiPartNumber {tiPartNumber} has been excluded and is not available for order. Remove {tiPartNumber} and resubmit the request. If further assistance is needed, contact TI Customer support center support.ti.com/csm |
| TI-TXT-019 | ERROR | Duplicate tiPartNumber is not accepted | tiPartNumber {tiPartNumber} is duplicated on quote. Duplicate will not be processed. No further action required. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-040 | ERROR | Discontinued | tiPartNumber {tiPartNumber} been discontinued. Contact your sales representative for an alternate part number. |
| TI-TXT-026 | ERROR | No quotes allowed for non-authorized channels / non-authorized reseller and /or non-validated or non-verifiable end customer. | For assistance, contact TI Customer support center (https://support.ti.com/csm). |
| TI-TXT-006 | ERROR | Invalid quantity | Quantity for {tiPartNumber} is not valid and must be greater than zero. Enter a valid quantity and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-002 | ERROR | Quote changes not allowed | Changes on Quote not allowed. If further assistance is needed, contact TI API Support (api-portal.ti.com/support). |
| TI-TXT-021 | ERROR | Quantity does not meet minimum order quantity | Quantity for {tiPartNumber} does not meet minimum order quantity of {quantity}. Enter a valid quantity and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-022 | ERROR | Quantity does not meet standard pack quantity | Quantity for {tiPartNumber} does not meet standard pack quantity of {quantity}. Enter a valid quantity and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-013 | ERROR | reason: Customer blocked from quoting due to customer delivery block | Customer is blocked from quoting due to customer delivery block. Customer must be unblocked to request quote or place an order. For assistance, contact TI Customer support center https://support.ti.com/csm |
| TI-TXT-056 | ERROR | Invalid requestedUnitPriceCurrencyCode | requestedUnitPriceCurrencyCode is invalid. Enter a valid requestedUnitPriceCurrencyCode and resubmit the request. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
| TI-TXT-055 | ERROR | Invalid TI Sold-To | Customer Sold-To missing or invalid. For assistance, contact TI customer support center https://support.ti.com/csm |
| TI-TXT-009 | ERROR | Invalid Distributor soldTo | Distributor soldTo is not valid. For assistance, contact TI customer support center https://support.ti.com/csm |
| TI-TXT-067 | ERROR | Invalid requestedUnitPrice | requestedUnitPrice is not valid and is different than the customer’s regional currency. Enter a valid requestedUnitPrice is the same currency as the customer’s regional currency. If further assistance is needed, contact TI API Support api-portal.ti.com/support |
View v2 Backlog quote API error codes and meanings (part 1 of 2)
