simplelink_cc13x2_26x2_sdk_3_40_00_02
1. Removing board constraints in SysConfig with "Custom Board" button causes unexpected build or runtime behavior.
Refer to this E2E FAQ: https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz/f/156/t/864899
2. Joining device (ZR/ZED) ignores PAN ID config settings and incorrectly associates when two ore more Zigbee networks respond to a beacon.
Apply the following code changes to bdb.c:
void bdb_filterNwkDisc(void) { networkDesc_t* pNwkDesc; uint8_t i = 0; uint8_t ResultCount = 0, ResultTotal = 0; //CHANGE THIS LINE pBDBListNwk = nwk_getNwkDescList(); nwk_desc_list_release(); pNwkDesc = pBDBListNwk; while (pNwkDesc) { ResultCount++; pNwkDesc = pNwkDesc->nextDesc; } ResultTotal = ResultCount; //ADD THIS LINE if(pBDBListNwk) { pNwkDesc = pBDBListNwk; if(pNwkDesc) { for ( i = 0; i < ResultTotal; i++, pNwkDesc = pNwkDesc->nextDesc ) //CHANGE THIS LINE ...
3. A malloc with size of zero will cause HEAPMGR_ASSERT
Place heapInitialize=1 after HEAPMGR_INIT calls HEAPMGR_MALLOC(0) in rtos_heaposal.h
4. Incorrect source offset results in NV corruption
Make the following change inside of nvocmp.c:
static bool NVOCMP_findSignature(uint8_t pg, uint16_t *pSrcOff) { uint16_t i; uint16_t rdLen; uint8_t readBuffer[NVOCMP_XFERBLKMAX]; uint16_t srcOff = *pSrcOff; uint16_t endOff = NVOCMP_PGDATAOFS + NVOCMP_ITEMHDRLEN - 1; while(srcOff > endOff) { rdLen = (srcOff - NVOCMP_XFERBLKMAX > endOff) ? NVOCMP_XFERBLKMAX : srcOff - endOff; srcOff -= rdLen; NVOCMP_read(pg, srcOff, readBuffer, rdLen); for(i = rdLen; i > 0; i--) { if(readBuffer[i-1] == NVOCMP_SIGNATURE) { // Found possible header, resume normal operation NVOCMP_ALERT(FALSE, "Found possible signature.") srcOff += (i); //CHANGE THIS LINE *pSrcOff = srcOff; return(true); } } } return(false); }
5. Zigbee devices do not rejoin (after a reset) if using install codes
Solution:
In bdb_StartCommissioning, replace the contents between the "#ifdef ZG_BUILD_JOINING_TYPE" and "#endif //ZG_BUILD_JOINING_TYPE" with:
#ifdef ZG_BUILD_JOINING_TYPE //Only for joining devices validate the joining procedure if(ZG_DEVICE_JOINING_TYPE) { //If we got into a network if(!OsalPort_isBufSet( AIB_apsTrustCenterAddress, 0x00, Z_EXTADDR_LEN )) { //Which is not distributed if(!APSME_IsDistributedSecurity()) { uint8_t found; uint16_t entryIndex; APSME_TCLinkKeyNVEntry_t APSME_TCLKDevEntry; entryIndex = APSME_SearchTCLinkKeyEntry(AIB_apsTrustCenterAddress, &found, &APSME_TCLKDevEntry); //If we must perform the TCLK exchange and we didn't complete it, then reset to FN if(requestNewTrustCenterLinkKey && (APSME_TCLKDevEntry.keyAttributes != ZG_NON_R21_NWK_JOINED) && (APSME_TCLKDevEntry.keyAttributes != ZG_VERIFIED_KEY)) { if(entryIndex < gZDSECMGR_TC_DEVICE_MAX) { //Force to initialize the entry memset(&APSME_TCLKDevEntry,0,sizeof(APSME_TCLinkKeyNVEntry_t)); APSME_TCLKDevEntry.keyAttributes = ZG_DEFAULT_KEY; osal_nv_write_ex(ZCD_NV_EX_TCLK_TABLE, entryIndex, sizeof(APSME_TCLinkKeyNVEntry_t), &APSME_TCLKDevEntry); TCLinkKeyRAMEntry[entryIndex].txFrmCntr = 0; TCLinkKeyRAMEntry[entryIndex].rxFrmCntr = 0; TCLinkKeyRAMEntry[entryIndex].entryUsed = FALSE; } //reset the device parameters to FN bdbAttributes.bdbNodeIsOnANetwork = FALSE; osal_nv_write(ZCD_NV_BDBNODEISONANETWORK, sizeof(bdbAttributes.bdbNodeIsOnANetwork), &bdbAttributes.bdbNodeIsOnANetwork); zgWriteStartupOptions(ZG_STARTUP_SET, ZCD_STARTOPT_DEFAULT_CONFIG_STATE | ZCD_STARTOPT_DEFAULT_NETWORK_STATE); //Then start the commissioning process requested bdbCommissioningProcedureState.bdbCommissioningState = BDB_COMMISSIONING_STATE_START_RESUME; OsalPort_setEvent( bdb_TaskID, BDB_CHANGE_COMMISSIONING_STATE ); return; } } } } #endif //ZG_BUILD_JOINING_TYPE
And in function ZDSecMgrTransportKeyInd of zd_sec_mgr.c, use this (ie fix is in the else block):
// If entry is found with keyAttribute ZG_PROVISIONAL_KEY, update extAddr and write to NV if(status == SUCCESS) { OsalPort_memcpy(TCLKDevEntryCpy.extAddr, ind->srcExtAddr, Z_EXTADDR_LEN); //Save the KeyAttribute for joining device osal_nv_write_ex(ZCD_NV_EX_TCLK_TABLE, entryIndex, sizeof(APSME_TCLinkKeyNVEntry_t), &TCLKDevEntryCpy); } else { // Find TCLK entry with TC extAddr or first unused entry uint8_t entryFound; entryIndex = APSME_SearchTCLinkKeyEntry(AIB_apsTrustCenterAddress,&entryFound,&TCLKDevEntryCpy); if(entryIndex < gZDSECMGR_TC_DEVICE_MAX) { OsalPort_memcpy(TCLKDevEntryCpy.extAddr, ind->srcExtAddr, Z_EXTADDR_LEN); //Save the KeyAttribute for joining device osal_nv_write_ex(ZCD_NV_EX_TCLK_TABLE, entryIndex, sizeof(APSME_TCLinkKeyNVEntry_t), &TCLKDevEntryCpy); } }
Ryan
