Low voltage DC/AC inverter solution
Guru 19655 points
Other Parts Discussed in Thread: PMP21404
I looking for Low voltage "DC/AC" inverter solution, required voltage is 5Vin_DC to 30Vout_AC / 10mA.
Please let me know about recommended solution above specification.
My thinking is below;
①I think that better to set Boost DC/DC and Controller.
 If there any solution for direct 5V_DC ⇒ 30V_AC is best.
②Is PMP21404 effective to reference above DC/AC solution?
http://www.ti.com/tool/PMP21404
Satoshi
  • Hi Satoshi,
    The design that you referenced is similar to the first block of your diagram. It is just a boost to the higher voltage, not a DC/AC converter.
    The wording in the title is a bit misleading.
    Unfortunately TI does not have an analog solution to make a DC/AC converter, this would need to be done with a micro controller or some sort of digital solution.
    Robert
