Part Number: CC1352P
Hi All,
Is there any documentation or SDK example available to add new endpoint.
Thanks & Regards,
Yasar Arafath
Hi All,
Thanks & Regards,
Yasar Arafath
Hi Yasar,
This is not directly covered by the Zigbee User's Guide but you can refer to the SLAs, YK's blog post, or OTA switch examples.
http://dev.ti.com/tirex/explore/node?node=AHfY0Eko1oL507RS1aRYoQ__pTTHBmu__LATEST
https://sunmaysky.blogspot.com/2020/04/how-to-use-two-endpoints-in-simplelink.html
http://dev.ti.com/tirex/explore/node?node=AFeUwo0Wje97dNR6PZTuJQ__pTTHBmu__LATEST
Ryan
Hi Ryan,
Earlier also I followed the same procedure by duplicating the Parameters and Callbacks as mentioned in YK's Blog to add multiple endpoints in zigbee.
For ON/OFF cluster it is simple. But we want to add it for Level Control cluster also where more number of Callbacks and functions are there to duplicate.
Right now able to add and check the second endpoint with ON/OFF cluster alone. We have to add four more endpoint with ON/OFF and Level Control cluster.
We will check and update you the same.
Thanks & Regards,
Yasar Arafath
