customer wants to wake up the CC2650 every 12hr. What is the best way? Using 2 chained timers or the RTC? Do we have an RTC alarm example project?
Regards, Holger
Regards, Holger
Holger,
There is an example of going into a low-power mode with a wakeup timer in this guide: https://dev.ti.com/tirex/explore/content/tirtos_cc13xx_cc26xx_2_21_00_06/docs/Power_Management.pdf
See section 3.3: CC13xx/CC26xx Reference Power Policy
Daniel
Hello Daniel,
customer told me that he don't want to go into low power / standby mode. He just need a 12hr timer. The standard timer is 32bit and can't do it. Therefore the idea was to use the 70bit RTC timer.
Regards, Holger
Holger,
There is an example showing how to use a real-time clock here: https://dev.ti.com/tirex/explore/node?node=AEltX787--5l4wqwg..jhw__Drd3Vmn__LATEST
You can also reference the Clock module (https://dev.ti.com/tirex/explore/content/tirtos_cc13xx_cc26xx_2_21_00_06/products/bios_6_46_01_37/docs/Bios_User_Guide.pdf) Specifically, the Seconds module might work for this application.
Daniel
