The installer throws an exception and terminates when starting to download files. The log file is attached
10:04:25 AM Wednesday, December 2, 2020 : Response Content length = 1527 10:04:25 AM Wednesday, December 2, 2020 : C:\Users\raymond.capotosto\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1527 10:04:25 AM Wednesday, December 2, 2020 : Reading Json URL File 10:04:25 AM Wednesday, December 2, 2020 : Setting TI Library URL from Json URL File 10:04:25 AM Wednesday, December 2, 2020 : Reading Json URL File 10:04:25 AM Wednesday, December 2, 2020 : setting media download server URL from Json File 10:04:25 AM Wednesday, December 2, 2020 : Reading Json URL File 10:04:25 AM Wednesday, December 2, 2020 : setting Dll path from Json File 10:04:25 AM Wednesday, December 2, 2020 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1 10:04:25 AM Wednesday, December 2, 2020 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer 10:04:25 AM Wednesday, December 2, 2020 : TILibPath is: https://software-dl.ti.com/pspice/esd/models/library/library.zip 10:04:25 AM Wednesday, December 2, 2020 : parameter count = 1 10:04:25 AM Wednesday, December 2, 2020 : -wrapper 10:04:26 AM Wednesday, December 2, 2020 : ReleaseVersion in XML: 17.40.004 InstalledVersion on system: 10:04:46 AM Wednesday, December 2, 2020 : error_code cdsVblRegisterInstallation: VblSuccess 10:04:46 AM Wednesday, December 2, 2020 : error_code cdsVblRequestLicense: VblSuccess 10:04:49 AM Wednesday, December 2, 2020 : Setting default Installation directory : C:\Cadence\PSpiceTI 10:04:54 AM Wednesday, December 2, 2020 : Checking for memory space 10:04:54 AM Wednesday, December 2, 2020 : Memory space available 10:04:54 AM Wednesday, December 2, 2020 : Target Dir: C:\Cadence\PSpiceTI 10:04:54 AM Wednesday, December 2, 2020 : Working Dir: C:\SPB_Data 10:04:54 AM Wednesday, December 2, 2020 : Exception has been thrown by the target of an invocation. 10:04:54 AM Wednesday, December 2, 2020 : Exception has been thrown by the target of an invocation. 10:04:54 AM Wednesday, December 2, 2020 : An exception occured when downloading file : https://software-dl.ti.com/pspice/esd/installer/software/setup.inx 10:04:54 AM Wednesday, December 2, 2020 : An exception occured when downloading file : https://software-dl.ti.com/pspice/esd/installer/software/setup.ini 10:04:54 AM Wednesday, December 2, 2020 : Deleting partially downloaded file: setup.ini of Size 0 10:04:54 AM Wednesday, December 2, 2020 : Deleting partially downloaded file: setup.inx of Size 0 10:05:02 AM Wednesday, December 2, 2020 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK 10:05:02 AM Wednesday, December 2, 2020 : Starting download of setup.ini Attempt no 2 DataSize is 2440 10:05:02 AM Wednesday, December 2, 2020 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini 10:05:02 AM Wednesday, December 2, 2020 : An exception occured which is causing the program to close. 10:05:02 AM Wednesday, December 2, 2020 : Details of exception are : Exception has been thrown by the target of an invocation. 10:05:02 AM Wednesday, December 2, 2020 : Stack Trace for the exception is at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args) at System.Security.Cryptography.MD5.Create() at TIPSpice.Utilities.GetFileChecksum(String filePath) at TIPSpice.FileDownloader.StartDownload() at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() 10:05:02 AM Wednesday, December 2, 2020 : Message: An error occurred and PSpice for TI 2020 needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\raymond.capotosto\AppData\Roaming\Cadence\PspiceTIInstall for error details. 10:05:02 AM Wednesday, December 2, 2020 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK 10:05:02 AM Wednesday, December 2, 2020 : Starting download of setup.inx Attempt no 2 DataSize is 558491 10:05:02 AM Wednesday, December 2, 2020 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx 10:05:02 AM Wednesday, December 2, 2020 : An exception occured which is causing the program to close. 10:05:02 AM Wednesday, December 2, 2020 : Details of exception are : Exception has been thrown by the target of an invocation. 10:05:02 AM Wednesday, December 2, 2020 : Stack Trace for the exception is at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Security.Cryptography.CryptoConfig.CreateFromName(String name, Object[] args) at System.Security.Cryptography.MD5.Create() at TIPSpice.Utilities.GetFileChecksum(String filePath) at TIPSpice.FileDownloader.StartDownload() at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() 10:05:02 AM Wednesday, December 2, 2020 : Message: An error occurred and PSpice for TI 2020 needs to close. Refer to cdsPspiceTIlog.txt at C:\Users\raymond.capotosto\AppData\Roaming\Cadence\PspiceTIInstall for error details.
Local firewall is turned off, but I cannot disable anti virus software.
Any suggestions?
Ray
