Part Number: CC1352P
Hi all,
We need use TX with different RF parameters(frequency, deviation, symbol rate...). In my test, sometimes, the system crash(not in while loop) after changing parameters. I provide my test code for your reference(if you decrease PACKET_INTERVAL, you can see this problem quickly). If I miss anything please let me know. Thank you
* Copyright (c) 2019, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/***** Includes *****/
/* Standard C Libraries */
#include <stdlib.h>
#include <unistd.h>
/* TI Drivers */
#include <ti/drivers/rf/RF.h>
#include <ti/drivers/PIN.h>
#include <ti/drivers/pin/PINCC26XX.h>
/* Driverlib Header files */
#include DeviceFamily_constructPath(driverlib/rf_prop_mailbox.h)
/* Board Header files */
#include "ti_drivers_config.h"
#include <ti_radio_config.h>
/***** Defines *****/
/* Do power measurement */
//#define POWER_MEASUREMENT
/* Packet TX Configuration */
#define PAYLOAD_LENGTH 120
#ifdef POWER_MEASUREMENT
#define PACKET_INTERVAL 5 /* For power measurement set packet interval to 5s */
#else
#define PACKET_INTERVAL 10000//500000 /* Set packet interval to 500000us or 500ms */
#endif
/***** Prototypes *****/
/***** Variable declarations *****/
static RF_Object rfObject;
static RF_Handle rfHandle;
static RF_Params rfParams;
static RF_CmdHandle rfCmdHandle;
/* Pin driver handle */
static PIN_Handle ledPinHandle;
static PIN_State ledPinState;
/* Pin driver handles */
static PIN_Handle buttonPinHandle;
static PIN_State buttonPinState;
static uint8_t packet[PAYLOAD_LENGTH] = {
1, 2, 3, 4, 5, 6, 7, 8, 9, 10,
11, 12, 13, 14, 15, 16, 17, 18, 19, 20,
21, 22, 23, 24, 25, 26, 27, 28, 29, 30,
static uint16_t seqNumber;
* Application LED pin configuration table:
* - All LEDs board LEDs are off.
PIN_Config pinTable[] =
CONFIG_PIN_GLED | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
PIN_TERMINATE
PIN_Config buttonPinTable[] = {
CONFIG_PIN_0 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_NEGEDGE,
CONFIG_PIN_1 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_NEGEDGE,
PIN_TERMINATE
* ======== buttonCallbackFxn ========
* Push buttons callback function.
void buttonCallbackFxn(PIN_Handle handle, PIN_Id pinId) {
/* Debounce logic, only toggle if the button is still pushed (low) */
CPUdelay(8000 * 50);
if (!PIN_getInputValue(pinId)) {
/* Toggle LED based on the button pressed */
switch (pinId) {
case CONFIG_PIN_0:
RF_cancelCmd(rfHandle, rfCmdHandle, 0);
RF_close(rfHandle);
rfHandle = 0;
RF_cmdFs.fractFreq = 0xE3CD;
RF_cmdPropRadioDivSetup.modulation.deviation = 0x8C;
RF_cmdPropRadioDivSetup.symbolRate.rateWord = 0xCCCD;
RF_cmdPropRadioDivSetup.rxBw = 0x27;
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioDivSetup, &rfParams);
rfCmdHandle = RF_postCmd(rfHandle, (RF_Op*)&RF_cmdFs, RF_PriorityNormal, NULL, 0);
break;
case CONFIG_PIN_1:
RF_close(rfHandle);
rfHandle = 0;
RF_cmdFs.fractFreq = 0xA334;
RF_cmdPropRadioDivSetup.modulation.deviation = 0x64;
RF_cmdPropRadioDivSetup.symbolRate.rateWord = 0x8000;
RF_cmdPropRadioDivSetup.rxBw = 0x52;
break;
default:
/* Do nothing */
break;
/***** Function definitions *****/
void *mainThread(void *arg0)
RF_Params_init(&rfParams);
/* Open LED pins */
ledPinHandle = PIN_open(&ledPinState, pinTable);
if (ledPinHandle == NULL)
while(1);
buttonPinHandle = PIN_open(&buttonPinState, buttonPinTable);
if(!buttonPinHandle) {
/* Error initializing button pins */
while(1);
/* Setup callback for button pins */
if (PIN_registerIntCb(buttonPinHandle, &buttonCallbackFxn) != 0) {
/* Error registering button callback function */
while(1);
RF_cmdPropTx.pktLen = PAYLOAD_LENGTH;
RF_cmdPropTx.pPkt = packet;
RF_cmdPropTx.startTrigger.triggerType = TRIG_NOW;
/* Request access to the radio */
#if defined(DeviceFamily_CC26X0R2)
rfHandle = RF_open(&rfObject, &RF_prop, (RF_RadioSetup*)&RF_cmdPropRadioSetup, &rfParams);
#else
#endif// DeviceFamily_CC26X0R2
/* Set the frequency */
while(1)
/* Create packet with incrementing sequence number and random payload */
// packet[0] = (uint8_t)(seqNumber >> 8);
// packet[1] = (uint8_t)(seqNumber++);
// uint8_t i;
// for (i = 2; i < PAYLOAD_LENGTH; i++)
// packet[i] = rand();
RF_EventMask terminationReason;
if(rfHandle != 0)
/* Send packet */
terminationReason = RF_runCmd(rfHandle, (RF_Op*)&RF_cmdPropTx,
switch(terminationReason)
case RF_EventLastCmdDone:
// A stand-alone radio operation command or the last radio
// operation command in a chain finished.
break;
case RF_EventCmdCancelled:
// Command cancelled before it was started; it can be caused
// by RF_cancelCmd() or RF_flushCmd().
break;
case RF_EventCmdAborted:
// Abrupt command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
case RF_EventCmdStopped:
// Graceful command termination caused by RF_cancelCmd() or
// RF_flushCmd().
break;
default:
// Uncaught error event
//while(1);
break;
uint32_t cmdStatus = ((volatile RF_Op*)&RF_cmdPropTx)->status;
switch(cmdStatus)
case PROP_DONE_OK:
// Packet transmitted successfully
break;
case PROP_DONE_STOPPED:
// received CMD_STOP while transmitting packet and finished
// transmitting packet
break;
case PROP_DONE_ABORT:
// Received CMD_ABORT while transmitting packet
break;
case PROP_ERROR_PAR:
// Observed illegal parameter
break;
case PROP_ERROR_NO_SETUP:
// Command sent without setting up the radio in a supported
// mode using CMD_PROP_RADIO_SETUP or CMD_RADIO_SETUP
break;
case PROP_ERROR_NO_FS:
// Command sent without the synthesizer being programmed
break;
case PROP_ERROR_TXUNF:
// TX underflow observed during operation
break;
default:
// Uncaught error event - these could come from the
// pool of states defined in rf_mailbox.h
//while(1);
break;
#ifndef POWER_MEASUREMENT
PIN_setOutputValue(ledPinHandle, CONFIG_PIN_GLED,!PIN_getOutputValue(CONFIG_PIN_GLED));
#endif
if(rfHandle != 0)
/* Power down the radio */
RF_yield(rfHandle);
/* Sleep for PACKET_INTERVAL s */
sleep(PACKET_INTERVAL);
#else
/* Sleep for PACKET_INTERVAL us */
usleep(PACKET_INTERVAL);
#endif
