[FAQ] What precision amplifiers should I use in my Infusion pump design
Infusion pumps have strict regulations that control their safety features such as the air-in-line detection and the pressure/occlusion sensors. There are also many different types of infusion pumps along with locations they may be used. This can make the task of designing an infusion pump system difficult. With TI’s wide range of options however, we will have a solution that works for you. The systems that precision amplifiers are most commonly found in are the:
  1. air-in-line sensor
  2. pressure/occlusion sensor
  3. motor current sensing.
The air-in-line sensor is used to prevent delivering large doses of air to a patient’s circulatory system. This signal path will use either an optical or ultrasonic sensor to detect bubbles. The amplifier in this signal chain will be used for signal conditioning into the ADC.
Specifications
OPA392
OPA2376
OPA192
Supply Voltage (V)
1.7 – 5.5
2.2 – 5.5
4.5 – 36
Vos max (mV) (max)
0.01
0.025
0.025
Drift typ (uV/C) (typ)
0.1
0.32
0.1
GBW (MHz)
13
5.5
10
Slew Rate (V/µs)
4.8
2
20
Voltage noise (nV/rthz)
6
7.5
5.5
Bias Current (pA) (typ)
0.8
10
20
Output Current (mA)
65
30
65
The occlusion sensors are used to prevent tube blockages that could lead to dangerous venous pressures or improper dosing. For occlusion sensing a strain gauge will be connected to the tube to measure the pressure on the line. For the highest accuracy an INA or op amp in a differential configuration will be used here.
Specifications
INA333
INA823
INA818
Supply Voltage (V)
1.8 – 5.5
2.7 – 36
4.5 – 36
Vos max (mV)
0.025
0.100
0.035
CMRR (min) (dB)
100
115
110
50
21
8
Bias Current (typ) (pA)
70
10.000
150
Quiescent current (mA)
0.05
0.2
0.35
A current sensing amplifier may be used to sense the current drive from any motors in the infusion pump.
Specifications
OPA391
OPA392
OPA333
Supply Voltage (V)
1.7 – 5.5
1.7 - 5.5
1.8 – 5.5
Vos max (mV)
0.045
0.01
0.01
GBW (MHz)
1
13
0.35
Slew Rate (V/µs)
1
4.8
0.16
Rail-to-Rail
In, Out
In, Out
In, Out
Bias Current (pA) (Max)
0.8
0.8
130
Output Current (mA)
60
65
5
For additional information on infusion pumps please see our infusion pump product page.
For more information see this 6406.Infusion pumps.pptx
