Other Parts Discussed in Thread: THS3215, THS4304, THS4141
To Whom It May Concern,
I would like to convert the differential output of the LMH6401 to a single ended 50 ohm output. Just using a single output from the part results in a high noise figure (since common mode noise is not rejected) and lower IP2. Using a balun doesn't appear to work due to the DC requirement. I haven't found a single ended output op-amp with OIP3's nearly as good as the LMH6401 at 3 GHz. Do you have any recommendations for the differential to single ended conversion?
Shawn
