Other Parts Discussed in Thread: OPA1637
Hi team i need Active 2nd order Elliptic filter design for Audio application can you please suggest any design reference i am unable to find anywhere in web.
Hello Narendra,
You stated in your other e2e post "I need to design a 2nd order differential active Elliptic filter for the sharp attenuation of -40dB/decade in stop bands and passband is 100Hz to 20KHz and one more filter with the pass band of 300Hz to 6KHz."
Here are my thoughts on an approach to fulfill the filter requirements:
Regards, Thomas
Precision Amplifiers Applications Engineering
Hi Thomas i already cascaded Chebyshev MFB two stages with low &high-pass sections but attenuation cannot be achieved with out allowing more ripple in the pass pand but in my application ripple should not cross 0.5dB ,since i need -40dB/decade as roll off in stop band i tried to tune the filter but i am getting peak overshoot at pole frequency. I read your application note slyt337 i am unable to find anything related to attenuation, passband ripple, damping, quality factor even in filter design tool also there is not enough resources to modify the capacitor and resistor values or changing the Damping factors.
Narendra,
Is this the same filter as your post here?
If so, I'd like to end this thread and just keep the focus on the thread above.
Mike
Hello Narendra,
I see that you have the other, earlier e2e inquiry already going on this filter subject that Luis, Kai and Michael have been assisting you with. Having two threads going on essentially the same subject matter taxes our internal TI resources and that of our friends outside TI, excessively. Luis will be providing you with a response via your other thread so I am going to close this version of the thread.
Regards, Thomas
