Other Parts Discussed in Thread: LMX2592,
We are trying to automate testing of the LMX2592 controlled via the USB2ANY. Our preferred automation is VBA Excel. We tried the ActiveX approach mentioned several places which would be perfect and simple. However, as many others, the communication to the USB2ANY when starting TICS Pro from within Excel VBA using the TI example code with ActiveX, connection cannot be established to the USB2ANY. It blinks 4 rapid blinks on the green LED, then pause, then repeat. Disconnecting and reconnecting is not helpful and only result in errors. Loading TICS Pro manually outside VBA Excel works fine.
I understand the new firmware is moving to TCP based automation, but in the SDK there is only examples for VB, not VBA. Is there any libraries and instructions for how to make this work, preferably as simple as the ActiveX approach. Updated the USB2ANY to latest firmware (2.9.x.). Any help on this would be most appreciated as we are running out of time.
