DEM-OPA-SOT-1A: DEM-OPA-SOT-1A
Part Number: DEM-OPA-SOT-1A
Image of this PCB has no standoff screw holes at four corners but PCB layout in the datasheet shows standoff screw holes. Can you confirm if demo board will have standoff holes?
I am looking for assembly drawing and pick and place files for this board to get assembled
  • Hello Ekta,
    As it would happen, the image is not of the DEM-OPA-SOT-1A but of a different PCB.  You can verify this by examining the placement of the four SMA connector locations, which do not match between the image and the user guide.  Please use the 2012 revision B user guide for your plans and understanding.  I will see if we have any images to update with website with; I apologize for your confusion.  The DEM-OPA-SOT-1A will have the standoff screw holes you expect from the user guide.
    Alec
  • Can I get Pick and place file and assembly drawing for this board so I can get it assembled?
  • Hello Ekta,
    As this EVM is a blank EVM board and you would need to populate the components yourself, TI does not have any pick & place or assembly files for the components on the DEM-OPA-SOT-1A EVM.
    You may use the component descriptions in Section 3 to properly size & select your components.
    Alec
