Hi Team,
I`m using TLV1805 in AC EV charger for control pilot signal, but I want to implement an isolated Control pilot signal.
Please, suggest us with the suitable solution.
Tarun Kumar
Hi Team,
Tarun Kumar
Hello Kai,
Thanks for quick response!
Referring to TIDA-010071 TLV1805 circuit
required isolation >=2.5kV on control Pilot OUT signal.
Yeah, an optocoupler will work, if it full fill the requirement.
Hello Tarun,
We do not have, nor are we planning, any isolated comparators.
The die cost would be prohibitive for such a simple function.
An opto-isolator is still the most effective solution for this application.
Hello Paul,
Can you please suggest, the suitable Opto-isolator for control pilot Signal as per the requirement
Thanks & Regards
Tarun Kumar
Hello Tarun,
That is a outside of our product expertise. There are many types from many manufacturers and your system and regulatory requirements will determine what device is appropriate.
I would start with the Fairchild/On Semi FOD817 opto-isolators used in the TIDA you mentioned above. That is a pretty typical LED + Phototranstor type opto-coupler.
