Dear Support member:
I have a design using LMH6733MQX at BMC ASPEED 2600 VGA output side, I had studied spec application design, and now I follow spec Figure34. Recommended Non-Inverting Gain circuit to design, but I have some questions that need help.
1. LMH6733MQX RF & RG resistor value How do setting? now I set 549 Ohm.
2. BMC 2600 VGA guide recommends RGB signal output needs to add Ferrite Bead between connectors, but I have LMH6733MQX so I add on LMH6733 output side. about the Ferrite Bead value, how do setting? and the Ferrite Bead will affect LMH6733MQX output signal capability?
3. How does LMH6733MQX output capability? How about Max Length segment of layout routing? And LMH6733MQX need closed host side or device side? would you Provide detailed layout guide document to me?
4. LMH6733MQX & LMH6738MQX what's different ? can Substitute? Does HW design need modification?
Thankful for your assistance.
2022-11-23
#Leo
