Other Parts Discussed in Thread: OPA838, THS4561, THS4551, THP210, THS4541, ADC3683
We have built an EVM for an 18-bit, 65MSPS SAR ADC for which we are using ADT1-6T+ transformer and OPA2625 in the below circuit configuration to drive the differential inputs of the ADC.
The theoretical noise floor (SNR) of ADC is around -85 dBFs. We expect the input drive circuit to have a much better noise performance so that it does not limit the noise floor of the overall system. It must also have good distortion performance (HD2 and HD3 is what we are mainly looking at). The ADC input must be at 3.2V peak-to-peak. Based on these constraints, OPA2625 was chosen considering the noise, HD2 and HD3 values specified in the datasheet. The op-amp is being operated in the high-drive mode.
In the above circuit, the feedback resistors R102 and R103 are set to 3K ohms and resistors R101, R104 are set to 1K ohms to obtain a gain of 4. The setup is being tested at an input frequency of 200KHz and ADC sampling frequency ranging from 22MSPS to 50MSPS. Here are many other configurations we have tried:
-Vary the gain (We would prefer to keep it larger so as to avoid having to supply a large RF input amplitude. Also, we are seeing a poorer performance when the inputs to the opamp need to swing high so as to compensate for lower gain)
-Keep the gain constant, but change the absolute values of resistors from low to high values
- Varied the supply rail values (Contrary to what is mentioned in the datasheet, we are obtaining better performance at a supply of Vs+ = 3V and Vs- = 0V)
- Added a lowpass RC filter (R = 5ohms and C = 200pF to ground) at the outputs of op-amp so as to limit the noise bandwidth
- Added a capacitor of 60pF in parallel to the feedback resistor (constraining that gain of the amplifier has to roll-off before the cutoff frequency of the RC filter) so that loading on the amplifier output can be minimized. Our idea was that quicker the capacitor starts to dominate the feedback as compared to the 4K ohm resistor, sooner its contribution to thermal noise at the output disappears.
Unfortunately, none of the above cases have yielded fruitful results. The SNR doesn't go beyond -72dBFs, HD2 and HD3 are around -75dBc in the best case. What's worse is that completely removing the op-amp and driving the ADC input with only the transformer improves our results to an SNR of -77dBFs, HD2 of -105dBc and HD3 of -90dbC. But, eventually having a transformer in the input path is not feasible as we are looking to provide DC sampling ability as well.
Please suggest any changes in our circuit that we may try to achieve better performance than what we are seeing now. Changing the op-amp could also be considered, in which case, please suggest a suitable one (I did come across articles that suggested current feedback op-amps as better ADC drivers than voltage feedback ones. If so, kindly elaborate the reasoning as well.)
