Hi Team,
Customer is having THS4521HD failures even after replaced the part. The replacement part still failed at 150C due to the high offset voltage drift. This failure delayed the delivery of theirPCB boards and production.
They're seeing around 7mV drift from 25C to 150C on failed parts. As in datasheet, the typical offset voltage at 175C is +/-0.13mV.
- Does TI test each this part at temperature?
- What is the offset voltage drift from 25C to 175C from your test?
- Is the offset voltage drift repeatable?
- Do you have any suggestions that we can screen this part before solder the part on board?
Also, may i confirm if THS4521EVM rated to high temperature?
Ernest
