Part Number: TLV9102
Hello Sir,
Hope this message finds you well,
I have few questions mentioned below, it will be appreciated if you provide your inputs here.
I am using below Voltage-to-current (V-I) converter circuit with BJT,
My application is ViMin = 0V , ViMax = 10V , IoMin= 0A , IoMax = 600mA
We are getting the output as expected with below configuration and same BJT 2N5686.
Please find attached simulation file.Section_AB_combined. 1.TSC
Could you please help us to understand,
1)Why in the your application selected BJT is 2N5686(Which has Icmax = 50A) and output required is Icmax = 1A?
2)Is there any relation of VBE vs Ic?
3)We are planning to use https://www.onsemi.com/pdf/datasheet/2n3019-d.pdf this 1A BJT because of size concern. is it workable solution?
4)How to select R3, C1 and R4 of your application? is there any equations or you can share any application notes?
Kindly guide us, your earlies response will be appreciated.
