Hi
We have a power module product that uses TI's OPA2172; in this production of 100pcs PCBA, 8pcs OPA2172 burned out;
The symptoms of a burned out IC are as follows:
1) Refer to the table for measuring the pin voltage of burned-out ICs. Most of them are burnt-out U7-2 op amps;
2) Among them, 1pcs OPA2172 power supply series resistors R28 and R29 are burnt and disconnected.
3) 2pcs board U4/U5 is also burned out
Need your support:
1) Check whether the schematic is correct or where it can be optimized; (If the sch is not clear enough, I can send you the PDF via friend)
2) What are the possible reasons for OPA2172 burning, and what analysis can we do?
Hope to receive your reply as soon as possible.
thank you for your support!
The sch diagram is as follows:
