Part Number: LM2901B
Other Parts Discussed in Thread: TLV1824, TLV1814, LM2901
Negative spikes appear on output pin when the comparator switches states if the output pin has a weak pullup. When using a hysteresis resistor the negative spike alters the trip point due to the hysteresis resistor
going negative. The negative spike disappears with higher pullup current.
1) Is this normal?
2) Is this due to the internal compensation capacitor of the LM2901B?
3) Any remedy other than higher current pullups?
Please see the attached document for schematic, layout, and scope traces of an example where two output pins have spikes and two output pins do not (on the same quad IC).
