Can you tell me what the difference is between PN TLC393QDRG4 and TLC393QDRG4Q1.
Cheers
Calum
Hi Calum,
When I search on the TLC393QDRG4 model it is listed with our commercial grade version of the product. It is rated for -40 C to +125 C operation.
Searching on the TLC393QDRG4Q1 lands on the automotive grade version of the product. The data sheet states that it is "Qualified for Automotive Applications." It too is rated for -40 C to +125 C operation.
The intended use appears that is the primary difference.
Regards, Thomas
PA - Linear Applications Engineering
Calum,
If you use ESP, go to each Product Folder page, the main parameters are shown and you can compare these side-by-side:
TLC393-Q1: TLC393:
Vio (25C)(Max)(mV) |
5 |
5 |
Iq per channel(Max)(mA) |
0.02 |
0.02 |
Rail-Rail |
Out |
Rail-Rail |
Out |
VICR(Max)(V) |
15 |
VICR(Max)(V) |
15 |
VICR(Min)(V) |
0 |
VICR(Min)(V) |
0 |
tRESP Low - to - High(us) |
1 |
1 |
Output Type |
Open Collector,Open Drain |
Output Type |
Vs(Min)(V) |
4 |
Vs(Min)(V) |
3 |
Vs(Max)(V) |
16 |
Vs(Max)(V) |
16 |
Pin/Package |
8SOIC |
Pin/Package |
8PDIP,8SO,8SOIC,8TSSOP |
Number of Channels |
2 |
2 |
Input Bias Current (+/-)(Max)(nA) |
0.03 |
0.002 |
Approx. Price (US$) |
0.46 | 1ku |
0.40 | 1ku |
Operating Temperature Range(C) |
-40 to 125 |
-40 to 125,-40 to 85,0 to 70 |
Rating |
Automotive |
Rating |
Military |
In addition, the qualification testing is much more rigorous for automotive (-Q1) devices than for commercial (non -Q1) devices. The tests typically have tighter specifications and have been tested 100% over temperature to meet the stringent needs for automotive devices.
The Q1 device meets the requirements of AEC-Q100 through both "binning"and testing per AEC-Q100.
http://focus.ti.com/download/auto/newsletters/autosolutions_04-09.htm provides a general explanation. See below:
AEC-Q100 is an industry standard specification developed by major automotive manufacturers and suppliers, which outlines the recommended new product and major change qualification requirements and procedures. It details a set of stress tests, defines the minimum stress test driven qualification requirements, and references test conditions for the qualification of integrated circuits.
Features:
- Qualified at -40°C to 125°C (represented in the part number by the "Q" designator) —180-day PCN period versus standard 90-day PCN meets automotive minimum requirements
- Q100 qualification data available on request —Single fab and A/T site help avoid shifts in performance or quality
Hey Leonard,
The specs above are the "best" case part - i.e. one that operates form 0C to 70C.
If I go into both datasheets and look at the table for -40C to 125C I see no difference in parameters. This is a question form a CM who I believe is looking for a drop in replacement. Are the two parts the same silicon and just tested differently? as one is automotive only and the other covers the full -55C to 125C range?
Cheers
Calum
