Following to this scheme, INA died after few hours.
At the beginning everything works fine,but after about two hours OUT voltage has started to grow up till it reached 3.4 Volts, which are more than supply voltage. Even if there is no current through shunt, high output stays.
So i assume, that IN+ and IN- cannot be higher than Vcc, although in datasheet it's not mentioned. (as i found on this forum, "over voltage" should be ok, but why that could happen? Two IC's died in that way).
P.S. output was directly connected to ADC of MSP430G2553
