Other Parts Discussed in Thread: ADS7861, OPA335, LMH6522, PGA117, PGA116, PGA2500, PGA281, VCA821, LMH6518, PGA308, PGA204, PGA309, PGA280, PGA206, PGA205, PGA202, PGA203, PGA112, PGA113, INA2132
Hello Everyone,
It has always been a pleasure to work with TI parts. many thanks for all the designers.
Following are my queries and related project inputs for resolving the queries.
I shall be grateful to have them resolved.
Requirement
Designing a Programmable (or Variable) Gain Control + Calibration block for ADS7861
Selections
ADC : ADS7861
Reference : 4.096 V reference (chip under selection)
Interface type : SPI
Input buffer : OPA335
Input Signals
Input 1 : 0 VDC to 100 VDC, Differential
Input 2 : 0 VDC to 100 VDC, Differential
Input 3 : 0 VDC to 10 VDC, Differential
Input 4 : 0 VDC to 10 VDC, Differential
Scaled down with a high impedance voltage divider and a buffer.
Queries
- What is the basic difference between a PGA and a VGA? On prima facie, both devices get a digital control input and adjust the gain of signal input.
- Considering above requirement whether to go for a PGA or for a VGA?
- Please confirm / deny my understanding about comparison:
- PGA would give inherent "Calibration" facility.
- VGA explicitly mentions "Differential" inputs.
- What is the difference between a Binary Gain and Scope Gain for a PGA? One can see the Binary Gain steps to be of the order 2^n. Is it the only difference?
- LMH6522 distinctly mentions "Differential input". Will a PGA also suffice the need?
- If PGA116 (or PGA117) be selected, is my understanding correct that no extra "Calibration" circuit block might be required?
- The selected ADS7861 has sampling rate of 500 kSPS. Will PGA116 (or PGA117) support it (as it will be the input block for ADS7861)?
- If answer to query 2 suggests use of a VGA, will VGA support this high speed of sampling?
- If a VGA is to be selected, which chip / chip-set would be useful for calibration?
- Does either of the devices support Differential Inputs? Idea is to feed the differential analogue input to PGA / VGA and to feed output of this stage to ADS7861.
Utpal Tembe
