Other Parts Discussed in Thread: OPA277
In the datasheet for the OPAx227 parts, Figure 15 shows the typical bias current change over temperature. I'd like to clarify my interpretation of this graph, as these typical bias currents (+/-0.5nA) are quite different than the typical bias currents given in the table (+/-2.5nA). The reason I ask is that a similar figure for the OPAx277 (Figure 11) shows something more like what I would expect (the "graph typicals" match the "table typicals" for that particular device).
So, regarding the 227, which of these interpretations of Figure 15 is correct:
This graph shows the ACTUAL bias current of a typical part over temperature.
Or, alternatively:
This is how much the bias current will typically CHANGE by over temperature (additive to a typical value in the +/-2.5nA range).
(Or, possibly, some other interpretation I'm missing).
I'm aware that the graph represents typical data and I should not count on it for exact analysis, however I'm just trying to get a feel for what kind of shift in bias current I might expectover a ~20C range. Is it also safe to assume the offset current could change by a similar amount?
