Other Parts Discussed in Thread: TM4C1294NCPDT, LM5007
Hello again,
Have recently noticed the INA282 output signal at times traverses 200mv or more below ground at the single ended SAR input TM4C1294NCPDT. Doesn't seem possible the INA output signal can even travers below ground when the REF1/2 inputs are tied to ground. Yet the scope captures indicate that is occurring and seems very odd that occurs anywhere in the INA output circuit.
Past efforts to stop false PWM comparator fault trips may be due to current monitors signal traversing far below ground at times?
https://e2e.ti.com/support/amplifiers/current-shunt-monitors/f/931/t/555537
Do you see anything in the INA output R divider that might cause the signal to traverse below ground?
Perhaps the INA (-14v) rail ability and shunt CMM is picking up FET body diode rectified forward current (di/dt) crossing the shunt?
BTW: MCU software blanking period is concurrent with low side FET on times, allow sampling of INA output only during reverse shunt current (ground to B+).
CH2: INA output at R8/R9.
