Other Parts Discussed in Thread: TINA-TI,
Tool/software: TINA-TI or Spice Models
I'm trying to simulate the single ended input impedance of the IC. We used Mentor System Vision and the TINA Spice model to export S-Parameters, the circuit is attached (s_param.png). We used a 50 ohm ac source and 2.5V offset for the common mode voltage. Afterwards I used the S-Parameter model to simulate the impedance inside another tool which I use for microstrip and filter desing. I used a 1A source and measured Vin which is propotional to Zin. I plotted the real and imaginary. (zin.png).
My plotted results look quite differently to the figure 36 from the datasheet (datasheet.png).
Where does this come from?
Can I trust the spice model?
Thank you.
