Other Parts Discussed in Thread: AMC1301, OPA365, TINA-TI
For example, input 0~1V sinusoidal signal, output 0~1V sinusoidal signal, and one of the output terminal is at the output ground.
As you can see the green curve I drew below. How to realize it?
If I directly connect VOUTN to the output ground, would VOUTP become VOUTP-VOUTN? Or this action will break this IC?
(I know adding an difference amp would help, but I don't want to add one more OpAmp, is there any other way?)
