LM339A: Can it be powered by +/- asymmetric power supply?
Genius 3870 points
Part Number: LM339A
we use LM339A as comparator under +/- power supply. there are two situations we need to confirm.
(1) V+ = +5.3V and V- = -5.3V
(2) V+ = +18.5V and V- = -5.3V
Coudl work noramlly under these power supply? If it can, what is the input voltage range and Vout High/Low range?
As in datasheet, the efffective Vin is 0~VCC-2V.
Thanks!
  • Hi Yi,
    the recommended common mode input voltage range translates to
    (1) -5.3V...+3.3V
    (2) -5.3V...+16.5V
    in your application.
    Vout_low would also be -5.3V. Vout_high depends on the supply voltage of the pull-up resistor. The pull-up's supply voltage should be no higher than +30V - 5.3V = +24.7V.
    Kai
