Other Parts Discussed in Thread: OPA188,
For a critical project, we need to know something about the long term Vos drift for this chip. IT there anything available?
Hey Tom,
There is very little actual long term drift data out there on these kind of parts (seems the references do more of that). However, there is some data to suggest the chopper devices do really well - essentially your output long term drift is more set by external element shifts. Perhaps the OPA188 should be of interest to you here,
www.ti.com/.../opa188.pdf
Hi Tom,
We certainly had to measure and collect the OPA140 offsets at each of the read-points and determine the deltas in relation to our established delta limits. The devices had to fall below the maximum delta criteria in order to pass and be qualified. TI does not share that detailed information with customers as it is designated company confidential.
I can share with you a PowerPoint document that one of my colleagues prepared on the subject of the long-term stability criteria we use here in the Precision Amplifiers group. I believe that will provide you some insight to our practices.
Long-term stability_042619.pdf
Regards, Thomas
Precision Amplifiers Applications Engineering
