Hello all,
In application document for LMH3401 it is mentioned that the" device performance is optimal when the output common-mode voltage (VOCM ) is within ±0.5 V of
mid-supply and performance degrades outside the range when the output swing approaches clipping". Also it is mentioned that "the VOCM range extends from 1.1
V below the mid-supply voltage to 1.1 V above the mid-supply voltage when using a 5-V supply levels.
I appreciate if you elaborate more about the two different ranges that are defined here.
Thank you,
Samaneh
