OPA827: midsupply, VCM, VOUT
Part Number: OPA827
Hi officer,
I am just writing to enquire about 1 thing on the datasheet of opa827. Please see the highlighted part in the picture above. What is 'midsuppy', can I interpret it at the middle voltage level of +VS and -VS, in this case 0V?
And may I ask the meaning of 'VCM = VOUT = midsupply'?
Is this the initial test condition?
Is there any test circuit?
thanks,
Jim.
  • Morning Jim,
    That is just one way to handle single supply or balanced bipolar supply conditions. So if you are say +/-15V, that Vcm is 0V.If you are single 18V, that Vcm is 9V. Just trying to condition the spec table to be assuming the output is centered on the supplies.
  • Hi Michael,
    Thanks for your reply.
    Let's say VS+ = 18V and VS- = -18V. -> Midsupply = 0V.
    Why is Vout = Midsupply = 0V? Is that Vout got when there is no input?
    thanks,
    Jim.
  • Hi Jim,
    Yes, with +/-18 V supplies half way between that total 36 V span is 0 V. This condition is mid-supply, or the mid-point between +18 V and -18 V.
    Assuming the OPA827 is set up in a closed-loop gain with the non-inverting input at mid supply (0 V), the output voltage would ideally be 0 V too. However, due to the Op amp internal, no-ideal characteristics that contribute to voltage-offset, the output will be slightly off of 0 V by Voso = Vosi (1+Rf/Ri).
    Regards, Thomas
    Precision Amplifiers Applications Engineering
  • Hi Thomas,
    thanks for your help!
    BR,
    Jim.
