Hello team,
OPA197 integrates EMI filter inside the device and can reduce EMI effect from the source.
However, I think we still see the effect(offset shift on output) even with device integrating EMI filter such like OPA197.
- In the first place, how is EMI(high frequency signal) converted to offset shift on output?
SBOA128 explains internal diodes(silicon p-n junction) works as rectification and it converts ac to dc. However I would like to know more detail if possible. - Does the conversion occurs at input stage when EMI is applied to IN+?
- Does the rectification work even if EMI signal is small?
- Is Integrated EMI filter simple 1st order RC?
- If attenuation by the filter is not enough then we will see offset shift on output and this is EMIRR IN+ performance, correct?
