OP07D: Some parameters
Genius 15770 points
Part Number: OP07D
My customer would like to know the following parameters for OP07D.
Are these values available?
1.
TYP for Common mode input resistance
2.
MAX for equivalent input noise voltage
3.
Max for equivalent input noise current
4.
MAX and TYP for PSRR
5.
Power dissipation is defined as 80mW(TYP) and 150mW(MAX) for “Vo=0, No load” condition in the datasheet.
What is the voltage for these values, TYP and MAX?
Oba
  • Hello Oba,
    Please understand that the OP07D is very much a legacy op amp and the parameter limits the customer is requesting are not specified. Please see my answers:
    The input resistance listed in the OP07D Electrical Characteristics table is the differential mode input resistance typically 31 MΩ. The common mode input resistance for such bipolar input designs is very roughly as an approximation 1000x or more higher than the differential input resistance.
    2.
    TI does not specify maximum voltage noise for most every op amp, and not for the OP07D as well.
    3.
    TI does not specify maximum current noise for most every op amp, and not for the OP07D as well.
    4.
    Covert the following datasheet specification to dB:
    5.
    The Electrical Characteristics table states, "7.5 Electrical Characteristics at specified free-air temperature, VCC± = ±15 V (unless otherwise noted)(1)."
    Regards, Thomas
    Precision Applications Engineering
