Other Parts Discussed in Thread: TPS61022
I would like to use the INA181 current sense amplifier for my project. Currently intend to hook up an ATTiny 1-series micro, and use the DAC module to directly supply the Vref as a dimming method. Have copied the PMP4640 schematic for the most part, and followed the datasheet as best I can. The DAC module is a buffered resistor divider per Atmel data sheet, and it is supposed to supply up to 1ma current into a 5k ohm minimum load.
The Vout will be going to the feedback pin of a TPS61022 boost converter. The project supply will be using two nimh cells.
Would it be possible to pass on a pic of the board design for a board review if possible too. Thanks.
Kent
