Other Parts Discussed in Thread: TLC082, TLV172
I couldn't find the ESD(HBM,CDM) result of TLC081IDR on the Datasheet.
So, please provide it me as soon as possible.
BR,
Hello, BR,
There is no ESD in the data sheet as you have noted. I did find ESD testing results for TLC082 (the dual op amp) that passed 2kV HBM, 200V MM, 1kV CDM. Note that the data sheet does not make any ESD claims.
Would you like a alternate device suggestion?
Hi Ronald,
Thank you for reply.
I can't find the ESD testing results for TLC082 that you found.
Could you send me the ESD result data for TLC082.
As you know, If I download "Qualification Summary" on the TI WEB, In the result column of ESD, it says "See data sheet".
So, please send me the ESD result data for TLC082 instead?
YOO
Please refer to attached that is a qualification summary.
Reliability Summary_TLC081IDR-4115430.pdf
The data I found was an internal job that didn't become part of the data sheet and not part of the qualification summary. I can share the result, but I can't share the internal report in whole. Therefore if ESD qualification is required, then a different part part be used.
After all, from my point of view, TI does not have TLC081IDR ESD data, right?
Panasonic requested ESD data by pointing the product name of TLC081IDR.
YOO
YOO,
There is no ESD data. TLV172 is a good replacement and it does have ESD data. It doesn't have NULL pins
