Other Parts Discussed in Thread: LM317
Hi K Kamel,
I think that you missed the input common-mode voltage requirements in this part, see the link below.
The datasheet did not present 12V single supply rail in input Vcm vs. output voltage, but the plot should be similar to Figure 5.
I go ahead and rearrange your circuit (did not spend time to duplicate exactly what you had). Here is the captured image and Tina simulation. I can't explain the "different power supply" scenario, and it should not have worked either, unless your configuration is somehow falling within the input Vcm requirements, see the attache image above.
/cfs-file/__key/communityserver-discussions-components-files/14/INA118--LED-I-Sensing-06112020.TSC
If you have additional questions, please let us know.
Raymond
Hello sir,
thank you sir for your explanation, i will try to say what i have understood to make sure that i get it right, "input common mode voltage" means that the 2 signals getting to the instrumental amplifier, in this case"INA118" the 2 signals should be in the range from ((V-)+1.1 volt) and ((V+)-1 volt) which means that the 2 signals should be between (0"GND" + 1.1 volt ) and (12"VCC" - 1 volt ), did i explain it right?
Thank you again for your explanation and you effort.
Hi K Kamel,
Yes, normally you place the input common mode voltage in the middle of power rail, if you have large input signal swing.
If the input common voltage requirements are violated, the op amp will not behave linearly with respect to the input.
Raymond
