To whom it may concern,
I would like to you tell me regarding input voltage on LMH6553.
will you please confirm to attached file?
Can you clarify which node you are referring to when mentioning "Vi"? Is this the non-inverting node of the amplifier? Also you shouldn't provide an input to the device when the power is turned off, you will exceed the common-mode input voltage limitation on the abs max table and can permanently damage the device.
Hasan Babiker
