TL074: input offset voltage positive?
Part Number: TL074
in TL074's datasheet, the input offset voltage is a positive value, so as offset drift.
I wonder if it's really a positive value, or in fact it could be either positive or negative?
I guess we are just giving the absolute value in the datasheet.
The same question applies to input bias current, we are also giving a positive value, is it really positive or it could be either positive or negative?
  • Hello Howard,
    Offset is an error and no error would be zero value. Notice that there is no minimum, that is how it is certain that the Vio , α specs are magnitudes.
    The value for these specs can be positive or negative values.
    IIB is also a magnitude, however, a positive value is by far more likely. Reverse junction current of the JFET gate.
