OPA2810: Input voltage range
Part Number: OPA2810
We are planning on using OPA2810 in our Analog IO card. I need some clarifications.
Our requirement is +/-10V single ended. We will be using  +/-12V as Vs+ and Vs- supply voltages.
I am a little bit concerned because allowable input differential voltage is +/-7V in datasheet but the most positive input voltage is given as Vs+ + 0.3 and most negative is given as Vs- - 0.3.
  1. Is the +/-7V limit only for differential input?
  2. If we are using +/-12V supply can we go upto +/-11V input?
Could you please answer the above questions and confirm that we can use this part for our requirement?
