Hi Sir
May comparator can support 2 PWM(Frequency 25Hz~25KHz) input compare?
Bogey
Hi Sir
Bogey
Hi Bogey,
Are you wanting to use the TLV3202 to compare two PWM signals to two references?
I need more information on your design and your input signal(s). What is the max input voltage? What is the min input voltage?...
This information will help me better answer your question.
Joe
Bogey
Sounds like you’re monitoring each PWM signal individually. If that’s the case, the speed range you mentioned is good for the tlv3202.
Chuck
