OPA314: Common-mode voltage range
Part Number: OPA314
Hi team,
Good day.
Our customer would like to test the Vcm, common-mode voltage range, a parameter of OPA314? What are the methods available and circuits needed to implement to run the test?
Carlo
  • Former Member
    0 Former Member
    Hi Carlo,
    I assume by your question that the customer is simply interested in verifying the rail-to-rail input capabilities of the amplifier and not CMRR or something else.
    The easiest way to do this would be to simply place a sample device in a unity gain buffer, sweep the input voltage which will be the input common mode voltage, and observe the output voltage.  The OPA314 has a rail-to-rail output.  So, you will see the output voltage change with a change in input voltage up until you get pretty close to the rails at the output where the output itself will become limited before the input.
    This is just a rudimentary test to be run that can be done quickly and easily to verify the rail-to-rail capabilities.  Please let me know if the customer's questions is different.
    Daniel
