Other Parts Discussed in Thread: LM358,
I have a differential mode op-amp being used to attenuate an AC signal down to a reasonable level for a ADC. It has a 1.5v offset. Op amp power is 12v, AC is no more than 30V.
Using the LM358 the following calculation was spot on.
// resistor attuention 100k/2.4k = 41.6666666667
Using the LM7322, which should be a drop in replacement, I'm seeing greater attenuation. At the ADC end a computation of ~11v equals about ~9v. Working backwards I've calculated the equivalent resistor for the 2.4k as 1.85k, quite a difference.
Wondering what it could be, input bias current?
