Other Parts Discussed in Thread: PCM5122
Since the TAS5756M and PCM5122 share the same digital frontend, I assume you can achieve the same with a PCM5122 as you could with a TAS5756M from the DAC_OUT(A/B) pins. Is this correct?
If so: could these DAC_OUT(A/B) pins be used to branch off the audio signal for a headphone output for example?
See the below graphics wich illustrates my question.
Thanks in advance!
Kind regards,
Julien
