According to the datasheet for TAS2560 VIH and VIL is not valid for SDA/SCL, and I can’t find any data for SCL/SDA VIH and VIL in the datasheet. What is VIH and VIL for SDA/SCL pins?
TAS2560 datasheet, page 8:
Thank you for your answer. But unfortunately I don't think it answers my question. My question was about VIH_minimum and VIL_maximum, HIGH and LOW input voltages to the TAS2560 IC. What are the input voltage levels for VIH_minimum and VIL_maximum for SCL and SDA. According to the TAS2450 datasheet the VIH_minimum and VIL_maximum values stated there are not valid for I2C SCL/SDA and the datasheet doesn't say anything about VIH_minimum and VIL_maximum for SCL/SDA.
Thank you
