Other Parts Discussed in Thread: TAS5630
Hi All,
“The CLIP signal indicates that the output is approaching clipping. The signal can be used to either an audio volume decrease or intelligent power supply controlling a low and a high rail...”
That’s all I found about /CLIP signal in the TAS5630 datasheet … I would like to use this output to control my DC/DC Converter supplying my TAS5630 based amplifier. The converter will switch the output voltage rails from 25V to 40V in case of amplifier goes to clip the output signal. Therefore I would like to ask some details about it:
- What is the /CLIP threshold? Is it defined as % of the output signal or % of the supply voltage?
- How the /CLIP output behaves – is active just for short time every time when the single signal period is going to be clipped or is detecting the high signal level (still below clipping) and stays for a time to assure power supply have a time to regulate high rail of the voltage?
- What is the /CLIP detect-response delay time?
Thanks for your support!
Cheers!
Tomasz
