Other Parts Discussed in Thread: OPA2365, OPA615
Hi all
Would you mind if we ask OPA365?
Our customer is looking for following a substitute(Sample and Hold circuit device).
https://www.intersil.com/content/dam/Intersil/documents/ha53/ha5351.pdf
The customer will use it(Sample and Hold circuit) as amp buffer for ASIC'S ADC.
TI doesn't have similar products.(LF398 is out of spec.)
The customer's spec
-Power :3.3V
-Sample rate : 5MHz
-Input : 2CH
-Output :1CH
So, in case of Sample rate : 5MHz, does unity gain require 10 times?
That's why, should we consider OPA2365 + analog switch?
If you have some reference design, could you share it?
Kind regards,
Hirotaka Matsumoto
