Tool/software: Linux
when I use OPA170 as a unit gain buffer,does it work with a 5V supply voltage(single)
Yes the OPA170 can operate with a 5V supply in a unity gain buffer configuration. The input common mode voltage range is specified from 100mV below the negative supply to 2V below the positive supply. This means when using a 5V single supply in a unity gain buffer configuration the input signal can only go from -0.1V to 3V.
Thank you,
Tim Claycomb
